Clutch probs s2
hey i bought my 1st s2 a couple of weeks back, and im having probs with the clutch. she judders on take off and some times in between changing gears, only when im on the biting point tho...
the biting point of the cluch keeps changing every 5 minutes, most of the time its REALLY low, as in about 2mm from right at the bottom of the pedal travel, and the from 1 sec to the next it goes normal, the juddering gets less (still slight juddering though).
adjustment mechanism? (it went in my old 3i, but when it went i couldnt select gears at all, & i still can)
any ideas?
any ideas?
If it's got an ap paddle clutch in it this could be your problem, I've got one in mine & the car normally judders when pulling away / changing gear etc & makes a funny whining noise when changing back down through the gears as well which constantly gets taken the pi$$ out of by me & the other half
If it's a standard clutch you've got when was the last time it was changed ? if it was recently may be that it wasn't correctly lined up when it was placed against the fly wheel.
HTH
HTH
I posted the same thing a couple of weeks ago. Mine does the excact thing. Still havent found out what it is. Just gonna keeping using it until something goes, coz ive run out of idea's..
