Whats needed for a coil pack conversion
Old 26-01-2016, 10:59 AM
jason3249
jason3249's Avatar
Default Whats needed for a coil pack conversion
Hi people got another thing i would like to do
What will i need to run coil packs
Iv got cosworth management
Running efi
But got the old distributor wont to replace it with packs
Anyone know whats needed for the conversion
Or is there a kit out there
Thanks all
Old 26-01-2016, 11:19 AM
Rob_DOHC
Rob_DOHC's Avatar
Speak to MSD about their wasted spark conversion. This will let use use a zetec coil pack. Individual coil packs is a pretty involved conversion on the RST and you would need to make up a suitable mounting bracket remembering that the exhaust manifold is 1 inch away.
Zetec coil pack is the sensible way forwards..... what do you hope to gain from the conversion?
Rob,
Old 26-01-2016, 07:03 PM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
its easy.
1. fit a cam sensor kit to the end of the cam pulley
2. extra ignition amp and sub loom. (buy one with rev counter fix built in. only one type i know will have)
that)
3. wasted spark board wired into the ecu.
4. the coilpack and bracket leads etc to be fitted.
gap the plugs correctly and enjoy the extra power with correct mapping.
Old 26-01-2016, 08:59 PM
jason3249
jason3249's Avatar
Thanks for that info spoke to them and thay sell the kit for 370 i think thay Said
Got a cam sensor as got cosworth management and a crank sensor to
Wont to go that way as more reliable in my opinion
Old 26-01-2016, 09:33 PM
Rob_DOHC
Rob_DOHC's Avatar
Fair point, I have fitted a few of the MSD kits and was always impressed with instructions and quality of wiring. Its an easy install.
Rob,
Old 26-01-2016, 09:34 PM
Rob_DOHC
Rob_DOHC's Avatar
The extra power bit is mostly tosh btw.
Old 27-01-2016, 10:38 PM
Chas
Chas's Avatar
Was that fitted for Ł370?
Old 27-01-2016, 10:44 PM
Rob_DOHC
Rob_DOHC's Avatar
I wouldn't have thought so, I think that price is probably for an extra ignition amp, the ecu wasted spark board and the wiring loom.
John 2.9
16-11-2016 06:18 PM
nick8saff
Modellers Corner.
12-01-2016 03:01 PM
SmudgerByName
10-01-2016 03:14 PM
Fused7
04-01-2016 04:03 PM
Quick Reply: Whats needed for a coil pack conversion
