Engine management
Old Feb 26, 2015 | 07:39 AM
jonesy1381's Avatar
jonesy1381
Default Engine management
What's the engine management to convert to from MFI and roughly how much would it cost and where is the best place to get it from?
Old Feb 26, 2015 | 11:17 AM
cossirob's Avatar
cossirob
If your after aftermarket management the best advice for you is to find a good well known tuner that work on and know fords that is within reasonable distance from you and speak to them. Every tuner is different and have there own management they like to use, speak to them and tell you what ypur plans are. Prices very massively according to what you want your management to do and what your future plans are with the car. My kms management from devil developments started off at £1250 (a few years ago now) supplied and fitted and on top of that i had to have bigger injectors, fuel pump, map sensor and full lambda control think that took it to around £1800 and that was for an entry level kms ecu. Im kicking myself now that I didnt go for a higher spec ecu as when I had it fitted it was to a basic 200bhp rs turbo now ditched that and gone for a 400bhp zt so make sure you have a goal and stick to it otherwise youll be spending ££££ lol
Old Feb 26, 2015 | 03:06 PM
jonesy1381's Avatar
jonesy1381
Thank you for the advice pal. Much appreciated. Not sure if there are many or any at all that have much experience with these cars here in northern ireland
Old Feb 26, 2015 | 07:55 PM
Karlos G's Avatar
Karlos G
Balls Deep!
As cossirob has said, although just to point out any management can run any power levels assuming your not limited to a small MAP sensor, it has nothing to do with the price.
There must be some tuners in NI? They don't need to have RST experience as they will be fitting everything new, it's only a four cylinder 8v engine so not even slightly complicated to map.
Old Feb 28, 2015 | 09:10 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
I have a friend in Newry who has bought my spare tuning equipment for his team. He is able to tune many setups now. If it helps I can pass on details.
Old Mar 1, 2015 | 01:36 AM
jonesy1381's Avatar
jonesy1381
Yes please mate. That would be much appreciated
jay030787
Sep 18, 2015 07:34 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Old ford
Jul 31, 2015 06:50 AM
