Turbo conversion
Old Sep 23, 2014 | 05:40 AM
Turbo Al's Avatar
Turbo Al
Default Turbo conversion
I'm doing a turbo conversion on my mk5 1.3ohv escort, fuel supply, what do I use for tank/pump set up on her?
Has anyone done one before?
Old Sep 23, 2014 | 09:59 PM
HaggisTurbo's Avatar
HaggisTurbo
Would be an intank EFI pump mate, the Escos one or Fiesta Turbo one should do the trick here.
Old Sep 24, 2014 | 06:34 AM
Turbo Al's Avatar
Turbo Al
Cheers, do you think that would fit into the standard tank sender hole or replace the whole tank?
Old Sep 30, 2014 | 05:35 AM
Turbo Al's Avatar
Turbo Al
Any help appreciated? Am struggling with the fuel supply.
Read about a mk5 van had a fiesta rest fuel tank fitted but unsure how that works as filler necks are on different sides of the car if I'm not wrong
Old Sep 30, 2014 | 06:20 AM
nigel b's Avatar
nigel b
The xr3i / rs2000 tank would probably bolt straight in
Old Oct 1, 2014 | 05:23 AM
Turbo Al's Avatar
Turbo Al
Trying that, no one wants to post and post is to dear etc. I've a old erst tank, I could use the pump feed from that tank and weld it to my tank and rub s2 pump. Obviously not when it's fitted to the car tho
Old Oct 5, 2014 | 11:08 AM
slimwynn's Avatar
slimwynn
As above ^^^^^^^^^^^^^^^^just buy a escort cosworth fuel pump or fiesta pump and use your tank.
The pumps arnt that big long and thin http://shop.motorsport-developments....pump-256-p.asp
Old Oct 5, 2014 | 01:40 PM
Turbo Al's Avatar
Turbo Al
That's what I'll do. Just wasn't sure as my car has a mechanical fuel pump on the block would a pump fit in the my tank. I'll only have the sender unit in there
Old Oct 5, 2014 | 07:00 PM
slimwynn's Avatar
slimwynn
hmm i thought that it would of been a electronic pump, if it is a mechanical pump then you will have to change the tank as your tank wont have a swirl pot+ the sender will be different and you will also have to have a fuel pump relay wired in.
Old Oct 5, 2014 | 07:06 PM
Turbo Al's Avatar
Turbo Al
I have a erst tank and pump here, I tried it up earlier, the bolt fixings on the side look to line up so all I have to do it get the tank strap to fit then mount the pump.
Or
If I cut the pump feed pipe off the erst tank and weld it onto the standard tank then mount the pump.
I've a s2 mfi loom and that will have the fuel pump relay on it
Old Oct 5, 2014 | 07:25 PM
slimwynn's Avatar
slimwynn
That will work your just going to be missing the swirl pot in the tank which would be a problem if your low on fuel.
Old Oct 7, 2014 | 05:29 AM
Turbo Al's Avatar
Turbo Al
I'm always low on fuel
Old Oct 9, 2014 | 08:33 PM
slimwynn's Avatar
slimwynn
lol
Old Oct 9, 2014 | 09:13 PM
Turbo Al's Avatar
Turbo Al
Recon I've lined up a escort gti tank and pump
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
RSBryden
Sep 6, 2015 08:39 PM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
