Which EFI Flywheels Can I use?
Old 19-03-2014, 04:47 PM
HaggisTurbo
HaggisTurbo's Avatar
Default Which EFI Flywheels Can I use?
Hi All,
Doing the ST170/Blacktop Zetec Turbo conversion and I am having some trouble sourcing an EFI flywheel.
Is it just the Fiesta RS Turbo one I can use or can i use the Zetec RS1800 one? or the xr2i one? or even an xr3i 16v?
Are they all the same or is it only CVH one I can use.
I am mating it to a Ka Gearbox hence the need for the flywheel
thanks
Old 19-03-2014, 06:05 PM
Daveysaff
Skint Passionford User
Daveysaff's Avatar
Any EFi cvh item should be fine
Old 19-03-2014, 06:10 PM
xrmalin
xrmalin's Avatar
But if you use a cvh flywheel you'll have to open the mounting bolt holes up by a mm or so so that the Zetec bolts fit through it
Old 19-03-2014, 06:24 PM
studabear
studabear's Avatar
1.8 focus petrol flywheel Im sure I've read that it fits, no drilling either.
Old 20-03-2014, 01:22 PM
HaggisTurbo
My query was because Its an ST170 bottom end so I would have thought any zetec 2.0 litre flywheel would have done, connecting to an ib5 ka box? Or is there a specific reason it needs to be a CVH one? Confused.com lol
Thanks for your help folks
Old 20-03-2014, 01:41 PM
studabear
studabear's Avatar
2litre focus had a mtx box 1.8 had ib5
Old 20-03-2014, 07:18 PM
xrmalin
xrmalin's Avatar
The cvh flywheel is lighter too
Old 20-03-2014, 09:36 PM
studabear
studabear's Avatar
A few efi 2i/3i cars on ebay for breaking, might get a flywheel from one of them?
Old 21-03-2014, 12:37 AM
HaggisTurbo
Hi Stu got a Flywheel from a 1.8 Xr2i 16v which had a ib5 gearbox.
Old 21-03-2014, 09:05 AM
Karlos G
Balls Deep!
Karlos G's Avatar
This.
Should be fine then, you use an RST clutch too which is why a 220mm flywheel is also needed.
Old 21-03-2014, 12:00 PM
HaggisTurbo
Yup just need to organize a clutch and I can start building it all up.
Going to give it a good clean and a paint first though
arkeye
Ford Focus ST
20-02-2016 01:22 PM
Mark_
14
16-01-2016 05:27 PM
Jman-pat
Ford Focus Diesel
08-11-2015 01:29 PM
RSmark84
13-09-2015 01:29 PM
dms04
11-09-2015 01:57 PM
Quick Reply: Which EFI Flywheels Can I use?
