Best way to mount a rear ARB?
Old 04-03-2014, 09:20 PM
muz
Wye Valley Hardcore
muz's Avatar
Default Best way to mount a rear ARB?
I'm going to be fitting up my rear ARB on the weekend but want to know what way would be best to mount it.
I know that when the car is on its wheels it's needs to be straight and have full travel through the wheel travel, but which of these ways would be best to mount it to the tie bar?
I thought of two possible ways,
Mount it to a set of sliding clamps which the link would connect to and have it on the side of the bars like so,
The sliders would be made from steel tube with a slit cut into them and tabs welded to each side of the slit with a bolt going through, clamping the slider to the tie arm. Then, a threaded adaptor for the link to connect to in the middle.
Or mount it right at the end sharing the same bolt as the tie bar. The bolt would be an M12 12.9, but would there be too much load in the area? (Obviously with the bolt going the other direction)
These are the only two ways I can think of mounting it and keeping the bars in situ adjustable without totally remaking them.
Old 04-03-2014, 09:27 PM
dojj
Resident Wrestling Legend
dojj's Avatar
Just make sure it won't foul in full compression and full extension of the suspension
Old 05-03-2014, 11:50 AM
nigel b
nigel b's Avatar
mine uses a bracket across both parallel links
Old 05-03-2014, 12:02 PM
muz
Wye Valley Hardcore
muz's Avatar
Yeah, the spring will be removed from the strut and checked for travel and binding.
Due to the shape of the ARB it has to connect to the rear tie bar. I don't want to mess with the bar itself too much due to it scarcity.
Old 06-03-2014, 05:58 AM
kingbx95
kingbx95's Avatar
This is something that I have been thinking about a fair bit lately, I have the same rear arb and rear arms (albeit mef ones) .
All going onto my s2
. Initial idea was a set of sliding clamps as per the front set up.although I can't see why mounting turnbuckles on the end would be a problem as long the arb doesn't hang to low????
How much messing About did you have to do to get the bar to fit around fuel tank? Have seen a few later 16i's withtheinlet bigger tank have the rear arb fitted.
Old 06-03-2014, 07:13 AM
muz
Wye Valley Hardcore
muz's Avatar
The roll bar and mounts all need moving lower and new holes drilled then it just clears. There's pics in my resto thread.
The turnbuckles will need shortening to mount at the end, so I'll chuck them on the lathe if needs be.
Old 06-03-2014, 07:52 AM
kingbx95
kingbx95's Avatar
Cheers muz! That's great mate.
So are you leaning towards drop links on the end linking to the tie bar??
I may go the other route, but still very much undecided at the mo. won't be fitting it all for a couple of weeks yet though
Old 06-03-2014, 10:30 AM
muz
Wye Valley Hardcore
muz's Avatar
Yeah, I think I'm going to look this weekend about mounting it to the hub/cone link itself by welding a bracket directly to the con link. It can only help having the roll bar closer to the hub.
Old 06-03-2014, 10:55 AM
kingbx95
kingbx95's Avatar
That's what's been bugging me. Adjusting by sliding the clamp.along the bars would be great but will naturally have less leave rage at this point.
Whereas mounting on the end and adjusting via turnbuckles will make the greatest use of the arb
If that makes sense?
How short do you think you can make the turnbuckle?
Old 06-03-2014, 12:18 PM
muz
Wye Valley Hardcore
muz's Avatar
Centre to centre, at their shortest they measure 145mm. That's a turnbuckle with a link with lock nut either end. The shank on the joints measure 40mm so, I think they could safely be shortened around 20mm and the half nuts machines slightly, but no more than this. So each turnbuckle would measure 105mm ish.
If this is still too long then one of the male rose joints could be replaced with a female joint and they could screw together, but this might leave them too short. Without measuring I can't say what will fit.
Old 06-03-2014, 01:54 PM
kingbx95
kingbx95's Avatar
Yeh a male and female joint sounds good to me. Think that's going to be a better length but like you say won't know until its I front of you
I'll keep my eyes on this and your resto!!
Old 06-03-2014, 04:28 PM
muz
Wye Valley Hardcore
muz's Avatar
The length of a male joint from the end of the shank to centre bore is 62mm and for the female joint 54mm. Allowing a maximum length of 106mm (based on 10mm of thread engagement and a minimum length of 89mm. The joints could be shortened though to give a slightly shorter length, I guess.
Old 06-03-2014, 07:39 PM
zvh
zvh's Avatar
Not allot of help but looks like a nice set up 😁have u got dust covers for them rose joints ? Just wondering
Old 06-03-2014, 09:23 PM
muz
Wye Valley Hardcore
muz's Avatar
No, not yet. It's something I'll probably look into in the future, though.
yatta
21-05-2016 10:31 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
DPDISXR4Ti
Ford Fiesta
21-09-2015 03:51 PM
Quick Reply: Best way to mount a rear ARB?
