piston ring issues?
Old Nov 9, 2013 | 06:57 PM
Turbo Al's Avatar
Turbo Al
Default piston ring issues?
Just gone efi and got it running today. Didnt do 3-4miles on road test and when I got back the oil cap was off and there was a mess there and over on the breather side I have the standard breather with a pipe and micro filter on the end of it and oil had sprayed out that too
Now my first thoughts are piston rings are away but the engine and bay were dry in the frst donor car. Sort of hoping I never put the oil cap on right and cos that came of it caused the oil to blow through the breather system??
Any ideas?
Old Nov 9, 2013 | 07:00 PM
nykola's Avatar
nykola
What sort of boost are you running?, efi is more prone to spitting the cap off than mfi especially at higher boost levels. A crap oil cap will spit off at 12 psi
Old Nov 9, 2013 | 07:37 PM
Turbo Al's Avatar
Turbo Al
eh.....she hit overboost at 1.2 bar, thats 17psi
Old Nov 9, 2013 | 07:53 PM
RSmark84's Avatar
RSmark84
How old is that oil cap? they are meant to be serviceable items, the rubber seal fails and the cap become loose.
Is it easy to put the cap off by hand?
Also you really should be running an oil catch tank, with that little filter on one of the inlet.
If you buy the Mocal tanks the cap would be the breather 'filter'.
Old Nov 9, 2013 | 07:57 PM
RSmark84's Avatar
RSmark84
genuine cap:
http://www.ebay.co.uk/itm/Genuine-Fo...item2325a6db1e
Can vouch for the seller myself.
mocal tank:
http://www.ebay.co.uk/itm/Mocal-Allo...item5d43ece1e3
You'll have to blank one of the inlets off as the RS only has one oil outlet on the rocker cover.
Old Nov 9, 2013 | 08:04 PM
Turbo Al's Avatar
Turbo Al
its not bad, certainly not the slackest cap ive felt, ill order a new cap, think the catch tank will have to wait just tho
i had it running and took the cap off, put my hand over it and reved it a bit but didnt feel any pressure nor got oil on my hand
maybe do a compression test tomorrow
Old Nov 10, 2013 | 01:53 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Thats a lot of crank case pressure to blow that much oil out, boost is irrelevant as that much shouldn't be getting passed the rings, many cars run over two bar and have no issues.
If the cap blow off then either the breather system is blocked or as you say the rings a really goosed, but I'd expect a lot of blue smoke if they were.
Old Nov 10, 2013 | 07:57 PM
nykola's Avatar
nykola
I'd say get a new oil cap tbh. For that much oil if the engine were shot you'd almost certainly see evidence of it with some of the blue stuff as stated above.
Oil gets everywhere so give it a clean, turn boost down a tad and see how it is with a new oil cap.
Old Nov 12, 2013 | 09:17 AM
Turbo Al's Avatar
Turbo Al
Done a compression test. Got between 135psi and 145psi so thats not bad. Ill try a cap. Ive cleaned the breather pipes too
Old Nov 18, 2013 | 05:37 AM
Turbo Al's Avatar
Turbo Al
new cap fitted, still blows off, cleaned the breather pipes and pot out and put a bottle where the filter is at the end of the breather, next to nothing in it since thursday.
there is a little smoke from cold start up which id say is the valve stem steals, easy sort, no smake on or off throttle. left it ticking over for 10 mins yesturday and there wasnt a puff out the exhaust.
its not used oil and its not blown the dipstick out either
one way valves in the breather pot?
Old Nov 18, 2013 | 07:15 AM
Ben26's Avatar
Ben26
Get an original cap mate. Can not fault them. Make th3 rocker breathers atmospheric as well. Actually only the left one as the other is from the crank.
Old Nov 18, 2013 | 05:32 PM
Karlos G's Avatar
Karlos G
Balls Deep!
How have you got the breather system plumbed up? It sounds like your CC pressure has no where to go?!
Try just one hose from the rocker cover to block (stock setup) and then put the little filter on the other rocker cover outlet blocking off the returns on the EFI inlet manifold.... If it still blows the cap off then you have serious issues as that would almost be impossible! lol
Old Nov 18, 2013 | 06:50 PM
Turbo Al's Avatar
Turbo Al
Today I fitted the mfi breather set up. Still lifted the cap. I should have taken the breather filter home but never thougt. I wasnt sure about the returns on the inlet. I assume its ok to block them off
Job for tomorrow. Lol
Nov 1, 2015 06:53 PM
deathrider666
Sep 28, 2015 06:12 PM
SMILER258
Sep 28, 2015 09:04 AM
