HELP Wilwood 4pot brake conversion on s2 rs turbo
Hello everyone I'm after some braided brake lines for wilwood 4pots for my s2 Rs turbo, it is a male connector for the brake line on the brake caliper and I need a braided line that will definitely fit it, is there a off the shelf part for this or will I need custom made brake lines? I would really appreciate any help if anyone knows, thanks.
I am having the same problem with my willwood calipers on my Series1 RST, the thread on the bleed nipple is M10x1, the braided lines I had for the original calipers are way too short, I am thinking about getting some made with a banjo connection on the caliper, and the original connection to the metal brake pipe.
Where can you get braided lines made mate?? My problem is its a male nipple on the caliper and a male nipple on the end of the standard brake line "/ so I need a brake line made with a female nipple if you understand what I mean??
Matt Baxter
16-09-2015 08:30 PM
matman
09-09-2015 05:45 PM
Ben26
27-08-2015 08:56 PM
