coolant system problem
Old May 8, 2013 | 07:30 PM
s2 turbo dave's Avatar
s2 turbo dave
Default coolant system problem
Hi Guys
I have a series 2 rs turbo, within 2 mins of the engine running the temp gauge goes straight pass the red when the water is still cold but does not overheat the car, I have changed the temp sender switch ( white and vilot) , I've tried a uprated thermostat ( 82c ) and uprated fan switch, I have tried 3 different sets of rs turbo dashboard gauges, checked the resistance between temp sender switch and gauge and all is good.
When the car has been run there seems a lot of pressure in my spec r header tank and can hear it boiling in the tank, it has had a new head gasket a month ago
Any help would be very grateful as its making go mad
Cheers Dave
Old May 8, 2013 | 08:10 PM
studabear's Avatar
studabear
Water pump a good un?
Old May 8, 2013 | 08:20 PM
boeb's Avatar
boeb
How's the water flow thru your rad ....and as said did u change pump a time of head gasket change
Old May 8, 2013 | 08:22 PM
s2 turbo dave
Haven't checked the water pump wud that cause gauge issue's thou
Old May 8, 2013 | 08:25 PM
hybridford's Avatar
hybridford
If water pump wasn't doing its job then temp would potentially raise causing gauge to read high temps.
On a side note I ran my old s2 without a thermostat at all.
Feel the temp of top and bottom hose from rad too.
Old May 9, 2013 | 08:51 PM
s2 turbo dave
Cheers guys will change the water pump and just hope it sorts it out
Dave
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Botts
Sep 22, 2015 02:04 PM
dms04
Sep 11, 2015 01:57 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
ST-170
Sep 4, 2015 11:02 AM
