My '88 Series 2 RST
My '88 Series 2 RST
Purchased in October 2012, been working on it most weekends, and on ebay every night.
Already had GAZ coilovers, Stainless exhaust, RS 3 spoke steering wheel, -31 actuator, boost guage and Ahmend Bayjoo unlimited boost chip with high/low boost switch.
These 2 pics are the day I got it, with aerosoled bonnet and needing a proper polish and wax. Also knows as the day the fun began....
These 3 pics are as of yesterday. Still needs a proper polish and wax. It has had an airtec radiator with twin 11inch fans, low temp stat, polished charge carrier with DV take off, Collins DV, turbo heat sheild, 2 new headlights, 2 new indicators, new bonnet, replaced under bonnet sound proofing, removed the flamer kit, front panel and front inner wings stonechipped, oil temp, oil pressure, and volt meter added to where the centre dash vents used to be. Puma shift linkage fitted.
Plus a full service, inc leads, 071c plugs etc, and I swiss cheesed the airbox with a 24mm tank cutter.
Next job is hopefully a setup at Oddkiddcreations.
Still a work in progress but arent they all!
07-10-2015 12:56 PM
muz
30-09-2015 08:29 AM
