Back fire
Old Dec 24, 2012 | 10:22 PM
Turbotodger's Avatar
Turbotodger
Default Back fire
Hi all was out in my s2 rst to day and I was sitting in fifth gear at 70mph then put my foot down and just as it came on boost it dune a massiv back fire and the lost power just like I let of the throttle. Just wondering if this has happened two any one befor and if they no why it did it meny thanks
Shane
Old Dec 25, 2012 | 12:07 AM
simontrayler's Avatar
simontrayler
Hi mate. Is the car after this happened still boosting and is thr turbo cutting in as normal...?
I have an idea... But I'll wait till you answer the question before I have a stab!
Old Dec 25, 2012 | 12:13 AM
Turbotodger
After it happened it felt like I shut the key off so I let off the peddle then it ran normal I pulled over had a look to make shore it hadn't shit it's self then drove off and it boosted fine after that like nothing happened.
Thanks for responding
Old Dec 25, 2012 | 12:47 AM
Chopshop85's Avatar
Chopshop85
Once mine did something similar to boost cut was the vacuum pipe that goes to the ecu had managed to wiggle its way under the heater surround which squashed it a little bit. Just another thing to check.
Old Dec 25, 2012 | 12:46 PM
mgtkr1's Avatar
mgtkr1
how much boost is your car running? if youve got more boost than the standard ecu chip is limited to, it will do this. will boost higher in lower gears but when under load the boost cut will kick in. you say it boosted fine afterwards, was this in 4th or 5th? assuming it was (and the car is chipped to allow more boost and set up accordingly) then i think i may know what it is. i have a similar problem and it only occurs after the car hasnt been run for a while. once its been up to temp for a while, it behaves. its damp related and i think its moisture affecting the dizzy and/or hall sensor (the plug on the dizzy). the vac that goes to the ecu is a good shout though
Old Dec 25, 2012 | 02:13 PM
co55iewife's Avatar
co55iewife
a friend had an Evo 5 i borrowed for a while and i can remember if you booted it on a really cold morning as it came onto full boost and peaked it would BANG! and drop boost, and then drive fine again. it practically knocked your head off. Turned out if was blowing the spark out.
Old Dec 25, 2012 | 02:50 PM
Turbotodger
Thanks to all that have replied the car is running 15psi on a standard ecu and boosted fine after in all gears. at the time the car was warm ( I don't drive it hard until it has warmed up ) and is my daily drive so wasn't left starring for long.
Old Dec 25, 2012 | 04:12 PM
luke19790_3's Avatar
luke19790_3
Is it chipped ??
Old Dec 25, 2012 | 04:27 PM
Turbotodger
No it's not
Old Dec 25, 2012 | 04:45 PM
luke19790_3
That's your problem, can't run that boost
Old Dec 25, 2012 | 05:01 PM
Turbotodger
Ok thanks mate
Old Dec 26, 2012 | 09:21 PM
teahan's Avatar
teahan
i'm pretty sure around 10 psi is the max on a standard ecu, depending on what one you have. one of the downloadable articles goes into this in more detail.
Old Dec 27, 2012 | 04:10 PM
mentalasanything's Avatar
mentalasanything
10PSI on a hearts and diamonds ECU, 8PSI on others.
Lee
mint_s2
Sep 2, 2015 08:58 AM
ekjim
Aug 17, 2015 08:57 PM
Shows & Track Days
Aug 15, 2015 06:25 AM
