Which fans??
Which fans??
Right,
Got an airtec fmic an alloy rad, but not bought fans yet. Think there meant to go between rad an cooler, but which fans do I buy an where do I mount? On the rad or on the cooler? An do i buy fans that push the air or ones that pull the air?
Confused.com!
Any help!!
Confused.com!
Any help!!
I have twin spal fans on mine mounted between the rad and cooler, think you'll need fans to push air though the rad, had a quick look on eBay and it looks like the fans blades can be swapped round to make them suck or blow
I will have to see how they cope when the zetec turbo is fitted.
Edit to add we put a new relay and all new wiring in for the fans when we fitted them,
I'm goin Zetec turbo also, jus hopin it wont run too hot with this set up!
