What Are The 3 Most Important Gauges For An RST?
Old 20-09-2012, 11:24 AM
tejy
tejy's Avatar
Default What Are The 3 Most Important Gauges For An RST?
Old 20-09-2012, 11:43 AM
RichieST
RichieST's Avatar
Water temperature, oil temperature and oil pressure I should imagine
Old 20-09-2012, 11:44 AM
t16coupe
t16coupe's Avatar
most people nom have oil pressure oil temp and boost
Old 20-09-2012, 11:45 AM
luke19790_3
luke19790_3's Avatar
wideband if you're on MFI
Old 20-09-2012, 12:19 PM
rog
rog's Avatar
As above, oil temp/press. & boost, or AFR if you want to add that in as well, same for any turbo car really IMO.
Old 20-09-2012, 12:33 PM
martinmilne
martinmilne's Avatar
boost oil pressure and temp but afr is very good idea
Old 20-09-2012, 12:35 PM
joffy
SLOW LEARNER
joffy's Avatar
Fuel Pressure? Oil Pressure? AFR?
Old 20-09-2012, 12:36 PM
Jamie_EscortSport
Jamie_EscortSport's Avatar
Depending on spec (imo)
If low/mid setup
Oil pressure, boost, afr
If high (id probaly have 4)
Oil pressure, boost, afr n knock
Old 20-09-2012, 12:40 PM
pani_k
PassionFORD Member
pani_k's Avatar
Engine critical readings that would highlight a potentially fatal issue would probably be AFR, Fuel Pressure and Oil Pressure.
Old 20-09-2012, 01:03 PM
mgtkr1
mgtkr1's Avatar
id say oil pressure, water temp and oil temp. afr is important though, a gauge is a good idea, arguably more than oil or water temp.
Old 20-09-2012, 02:04 PM
haz87
haz87's Avatar
Oil pressure, back up oil pressure and AFR.
Personally i'd go (and have 2 of these already) oil pressure, volts (at fuel pump) and AFR
Old 20-09-2012, 02:07 PM
martinmilne
volts at fuel pump is good one also have mine wired to fuel pump
Old 20-09-2012, 02:14 PM
tejy
tejy's Avatar
Think I'm going to go for an oil pressure, boost and AFR gauge.. Heres a pic of my gauge pods I've been collecting.. Sorry for the bad pic!
Old 20-09-2012, 02:19 PM
simonmcf
simonmcf's Avatar
recommendations for AFR?
Old 20-09-2012, 04:01 PM
homer j
homer j's Avatar
I'd suggest fuel pressure as number one, AFR number two and oil pressure number three. these to me are the ones that matter most on any turbo car, not just S2's on MFi.
regards
Tom
Old 20-09-2012, 04:29 PM
milesy23rst
PUG 306 GTI-6
milesy23rst's Avatar
Definite afr, oil press, fuel press imo
Old 20-09-2012, 05:02 PM
studabear
studabear's Avatar
AEM on mine, paid about Ł150 for the full kit, from www.efi-parts.co.uk
Old 20-09-2012, 06:07 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Or a Techedge 2J2 from http://trigger-wheels.com/store/contents/en-uk/d27.html is also good value.
Old 20-09-2012, 06:12 PM
jessie_rs
jessie_rs's Avatar
dont most of the AFR's need to have some sort of lamba boss to read accurately?
Old 20-09-2012, 06:42 PM
gus
gus's Avatar
gearbox self destruction gauge would be nice
Old 20-09-2012, 07:09 PM
botters
competant bodger
botters's Avatar
3 oil pressure guages all different brands so you can be sure of the accuracy lol
Old 20-09-2012, 07:52 PM
fraser9764
fraser9764's Avatar
What's the point of an oil pressure gauge? By the time you have seen it drop your engine is scrap
I have a dual oil pressure and temp, boost and AFR. Would like to invest in a knock sensor too.
Old 20-09-2012, 08:49 PM
AJC
AJC's Avatar
Oil pressure light comes on at 7 psi iirc
Now, if you have a gauge that usually reads 40 psi when warm
And it's reading 25 then you know something is a miss before your engine dies.
Old 20-09-2012, 08:51 PM
botters
competant bodger
botters's Avatar
but cross, a cvh owner will never see figures as high as those unless they are using 75/90 engine oil lol
Old 21-09-2012, 06:43 AM
AJC
AJC's Avatar
It's an example Botters you tit!!!!
Old 21-09-2012, 06:54 AM
Kris_23
Kris_23's Avatar
Revs, Speed and Fuel?
Old 21-09-2012, 08:27 AM
simonmcf
simonmcf's Avatar
How does the AFR hook in? is it into sensors already on the mfi or are new sensors needed? Damn you guys! my shopping list has just gotten bigger!
Old 21-09-2012, 08:32 AM
ROB7656
ROB7656's Avatar
Talking
A rotometer!
Old 21-09-2012, 10:09 AM
Rogeyboy
Rogeyboy's Avatar
Id say afr is more important than fuel pressure...
Oil temp and pressure also.
Volts is a good idea, esp from pump!
Old 21-09-2012, 11:12 AM
Karlos G
Balls Deep!
Karlos G's Avatar
TBH on old cars like these you ideally want to be monitoring everything! lol
But, I had oil pressure and temperature, boost, AFR (well, a lean warning light) and water temp.
Old 21-09-2012, 02:22 PM
Ryoishikawa
Ryoishikawa's Avatar
Boost , volts and oil temp
Old 21-09-2012, 02:43 PM
bigkevin
bigkevin's Avatar
+1
Old 21-09-2012, 07:31 PM
Rob_DOHC
Rob_DOHC's Avatar
Thats a really good idea mate, like it.
I've heard a few people say the same but I disagree. My oil pressure gauge saved my new and pretty damn expensive engine. My turbo oil drain to sump split and dumped half a sump of oil over the drive, first I knew of it was a flickering gauge needle, killed the ignition straight away and saved a few grand.
For low-mid power I would suggest:
AFR, Oil pressure and boost.
For any decent power I would have:
AFR, EGT (surprised no one mentioned it), Boost, Oil temp (if on track) and knock (but decent knock gauge like phormula, none of that rubbish tripe you see on ebay.
EGT is an incredibly powerful gauge to have, it really does tell you a lot about whats going on, and is one of the few gauges that will give you enough notice to save an engine, especially if running high boost/power.
Rob,
Old 21-09-2012, 07:51 PM
botters
competant bodger
botters's Avatar
ha ha sorry moy laavveerrrr
Old 21-09-2012, 08:03 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Rob,
Rob makes a very good point here, many things can be seen from EGT's... Mixture, timing, even detonation!
Old 22-09-2012, 05:33 PM
Rogeyboy
Rogeyboy's Avatar
EGT in each cylinder or in the downpipe?
Wheres the best place to get a knock sensor/warning light from?
Old 23-09-2012, 11:06 AM
teahan
teahan's Avatar
innovate wideband is the one that gives me peace of mind
Old 23-09-2012, 11:25 AM
crazycage
crazycage's Avatar
egt in the down pipe as close to the turbo as you can get it.
Old 23-09-2012, 02:41 PM
Karlos G
Balls Deep!
Karlos G's Avatar
For each cylinder is the perfect setup, but costly! Otherwise as Gary says.
Old 23-09-2012, 07:18 PM
orion_crazy_carl
orion=mini saff
orion_crazy_carl's Avatar
so its gone from 3 gauges to the cockpit of a jumbo
Quick Reply: What Are The 3 Most Important Gauges For An RST?
