fan staying on?
fan staying on?
just got my s2 rs turbo from my moms and went for a drive and when i pulled up i noticed the fan was staying on when you turn ignition off it goes off but when you put ignition on its on what could be causing this? the fan switch?
Boost Junkie
on the inner wing near the fuse box theres 2 little black connectors, if there together then fans set to come on with ignition, if they arent then prob the fan switch stuck
SMILER258
28-09-2015 09:04 AM
