noiesey tapets
noiesey tapets
what is the cause and what can be done to prevent it i know cvhs are tappey anyway but my turbo is very quiet however the other halfs fiesta is very noisey do they get more tappey with worn cams ?
Boost Junkie
yes the pressure will drop around that tappet and so will have poor lubrication, best to take cam out and inspect it and lifters. check the sleves for marks. if a tappet is hard to remove then dont force it as this will damage the sleave, it will have to drop out the bottom. its more than likely the cam and lifters though
No, uprated cams vary. Alot of Kent & Pipers selection use hydraulics. Newman only do solids now (they did do a hydraulic but it was shit and killed a few engines with swarf (mine included )).
That said, the lifters that come with Kent are absolutely shite! When i was using their cams i used to source other lifters rather than using their supplied items. Piper ive never used so cant comment
its already got a piper t2 cam in so would putting a std cam in change the running as its set up with that cam in and she uses it everyday so need to change it and get it back on road for next day and or if i got a kent cam would i need the kit or could i just replace the cam ?
Whatever you do , you will need to fit a new cam with new lifters.
You cannot mix:
Old cam new lifters
New cam old lifters
Old cam old lifters that weren't together in the first place.
All of them will fail prematurely and take a few bearings out with the swarf they produce.
If your in a rush, go get a standard cam with lifters for £90 from a motorfactors and away you go
You cannot mix:
Old cam new lifters
New cam old lifters
i spose a new std cam cant be worse than a badly worn uprated cam
i know you have to use new tapets and cam but dont uprated cams use stronger springs? would this affect a std cam
Some people fit "uprated" springs yer. But half the time these springs are softer than Fords standard springs
Would only take an extra 20mins to throw some ford springs in if you wanted. But tbh i cant see 'uprated' having a detrimental effect on a std cam
Boost Junkie
piper use to use double valve springs but these have a tendancy to pull the rocker studs out of the head, as said above mate you can get a new standard cam with lifters for around £100, i did on my last cvh and it ran smooth and pulled just as well as it did with the piper in it.
Mark_1
27
26-12-2010 07:23 PM
