Testing coolant temp sensor
Old Sep 11, 2012 | 01:01 PM
paul-h's Avatar
paul-h
Default Testing coolant temp sensor
As title lads after some info used the search and couldn't find anything?
Cheers, Paul
Old Sep 11, 2012 | 07:50 PM
paul-h's Avatar
paul-h
Anyone?
Old Sep 11, 2012 | 09:11 PM
adam151082's Avatar
adam151082
Id like to know how to test the fan switch?
Old Sep 12, 2012 | 11:47 AM
Rogeyboy's Avatar
Rogeyboy
Put em in a saucepan, slowly heat the water up to boiling. Use a thermometer and see when they activate using a multimeter i guess?
Old Sep 12, 2012 | 12:37 PM
martysmartie's Avatar
martysmartie
You replace, for the CTS you would need to know the resistance VS temp scale, for the price you would just buy a new one.
For the fan switch you can check the continuity of a hot engine or heat up a saucepan, as said.
Martin
Old Sep 12, 2012 | 06:41 PM
adam151082's Avatar
adam151082
Martin
Explain please??
Old Sep 15, 2012 | 12:09 PM
martysmartie
Originally Posted by adam151082
Explain please??
By placing the end of the switch is a saucepan of water of a suitable temperature, you are simulating the coolant reaching this temperature, therefore giving a resistance/continuity value on a multimeter connected as the switch closes.
Martin
Old Sep 15, 2012 | 05:11 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Using a miltimeter to meassure resistance...
Coolant:
5C........ 71900
36C...... 18300
100C..... 2000
So... In the fridge, under your armpit and in boiling water lol
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
