Mk5 escort zvh t l6 management
Old 22-07-2012, 09:29 AM
londee
londee's Avatar
Default Mk5 escort zvh t l6 management
2.1 zvh turbo with cosworth L6 management ..
Hi guys ive got a really strange one here ..for some reason my fuel pump has started running constantly when ignition is on before starting ..and very weirdly wont go in gear when this happens the other day I put a new ecu relay in and that cured it and it would go in gear fine ..But I went to go on a test drive i barely got off the drive and it cutout completely no ignitiion lights at all I found that the yellow 60amp fuse had blown
So fitted new one but now have same problem again fuel pump constantly runs and car wont go in gear when this happens it also causes the fuel regualater to screem ..ive even dissconnected the cps sensor stil no difference.. Its strange cos I had a problem with
The lights which caused a relay on the fuse board to go since then ive had this problem..??
Old 22-07-2012, 09:48 AM
studabear
studabear's Avatar
so the relay you had go, did you replace it with the correct item? try removing the relay you replaced and see what happens?
tonicosworth
Ford Escort RS Cosworth
31-10-2015 08:40 AM
FlashRS
14-09-2015 12:36 PM
3dr cossie
Alloy wheels and ICE for sale
02-09-2015 08:58 PM
Bighandsuk
02-09-2015 05:23 PM
Seanyfarrell
14-08-2015 11:37 PM
Quick Reply: Mk5 escort zvh t l6 management
