Central locking problem ...now fixed!
Old Jul 18, 2012 | 04:03 PM
drl's Avatar
drl
Default Central locking problem ...now fixed!
Hi central locking started playin up, locking and unlocking (the fuse is currently out!).
When I sit in the car and lock the car from drives side the drivers side just locks/unlocks but when I lock from passenger side the passenger side and boot lock/unlock ... Am I right in thinking there is a problem with wiring/solenoid on drivers side?
Old Jul 18, 2012 | 05:50 PM
Ryoishikawa's Avatar
Ryoishikawa
I had the same sort of problem took the door card off to find that the connectors were not really touching and needed a clean . Job done
Old Jul 18, 2012 | 06:29 PM
neil73's Avatar
neil73
Try spraying your locks with wd40 while you've got your door cards off, also the boot lock, mine where sticking making the car lock and unlock over and over
Old Jul 19, 2012 | 02:17 PM
gpm89's Avatar
gpm89
Exact same problem mate, for me it was the wiring connector behind the passenger side speaker pod
Old Jul 19, 2012 | 05:41 PM
drl's Avatar
drl
I checked wiring behind both drivers and passengers speaker pod and both white plugs behind door cards and still same problem.
If I lock from passenger side the passenger side and boot unlock/lock (and drivers lock doesn't do anything) but if I lock from drivers side the drivers side just unlock/lock (and the passenger side and boot don't do anything) ..... I'm guessing there is a problem with the drivers side solenoid???
Old Jul 19, 2012 | 07:55 PM
makaveli96's Avatar
makaveli96
Try looking at the wires that come from the inside driver's door going through the car where the inside door hinges are.
Old Jul 20, 2012 | 04:20 AM
gpm89's Avatar
gpm89
Quite possibly but before you buy another one i would check the earth and all connectors as they get dirty and oily and after all they are 25 years old haha. Also i would get a multimeter and check the power going to and from
Old Jul 20, 2012 | 07:30 PM
drl's Avatar
drl
Prob fixed ... The red plug behind the speaker pod had seen much better days! By passed it and all working again!
Old Jul 20, 2012 | 08:29 PM
gpm89's Avatar
gpm89
Good stuff
nico12
Dec 31, 2015 04:42 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Ronnie Scott
Sep 20, 2015 10:21 PM
Cos500
Sep 16, 2015 09:50 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
