Another abs thread
I know I know its been done before.
Looking to remove the abs from my S2. Does anyone have pics of the install of the non abs system?
Does the s2 master and res bottle have 2 or 4 holes?
I think I may have an xr31 master and I also have the hard back pipes for the rear with the balancing valve. I plan to put cossie rears on her.
thanks guys, pictures make things more understandable for me.
plenty of info with a search,
i've just removed mine, by repiping under the bonnet to eliminate the modulators,
some people will say remove master cyl and replace with A none abs master cyl and the under bonnet regulator (positioned on offside) and aslo then remove the rear load valves and pipe straight to the rear cylinders or calipers
