Efi question
Old Jan 2, 2012 | 06:29 PM
fastash1's Avatar
fastash1
S2 sold :(
Default Efi question
Hi all,
just wondering how much ££'s I would be looking at plus how much time to convert, ?? Is it engine out or what?
Thanks in advance
Ash
Old Jan 2, 2012 | 06:50 PM
luke19790_3's Avatar
luke19790_3
fiesta turbo or late rs turbo
Old Jan 2, 2012 | 06:52 PM
fastash1's Avatar
fastash1
S2 sold :(
What's best? I am new to this
Old Jan 2, 2012 | 06:59 PM
luke19790_3
same but fiesta is easier.
depends on how much money you have, i would fit a efi inlet and then have omex ecu fitted.
Old Jan 2, 2012 | 07:04 PM
fastash1's Avatar
fastash1
S2 sold :(
Wil that mean I don't need to change the flywheel??
Old Jan 2, 2012 | 07:07 PM
luke19790_3
different ways to do it but you will need a cps, best way is with the flywheel but i have done it on the lower pulley with a 36-1 tooth wheel.
Old Jan 3, 2012 | 06:05 AM
wedge07's Avatar
wedge07
I just bought a full fiesta rst engine. Box. Loom ecu etc everything needed then swapped engines n looms in a day on my own. Then next day plummed it and tidyed up loom n bay. Easy
Old Jan 3, 2012 | 07:00 AM
Rogeyboy's Avatar
Rogeyboy
Using an OFAB or OFAC loom has another advantage in that you can upgrade to plug and play megasquirt at a later date! Which is the conversion i have gone for!
Old Jan 3, 2012 | 03:14 PM
wedge07's Avatar
wedge07
Is megasquirt decent mate as i was lookin at upgrading from ofab. But my tuner told me to not bother n go for omex 600 even though its like double the price??
Old Jan 3, 2012 | 04:22 PM
Rogeyboy's Avatar
Rogeyboy
He's told you that so he can charge you an extra fee for the ecu itself and then an extra fee to map it. IME its no better when you look at the spec sheet for each, unless someone can correct me!? Once youve plugged your OFAM ecu in, load your laptop up with tunerstudio and start mapping it yourself, everytime you make a new modification you can re-map your car to suit, and spend quality time on it aswel, mapping different loads and rpms and various boost levels etc rather than just mapping flat out throttle like most tuners would...
Check my sig out m8!
Old Jan 3, 2012 | 04:56 PM
luke19790_3
i've got ms2 and for the price you can't go wrong. But omex is better if you're not going to map it or fit your self. Think more people/tuners will touch omex
Old Jan 3, 2012 | 04:58 PM
wedge07's Avatar
wedge07
Your sig? How would i map it myself? I suppose i could get used to it easy enough?? How much u talking for ecu n loom? Or does ecu just plug in my ofab loom?my tuner quoted me 1500 for omex600 ecu n loom. Him to wire n map it??
Old Jan 3, 2012 | 05:17 PM
luke19790_3
think i paid £365 from efiextra then you will need a lambda sensor think that was £165
Old Jan 3, 2012 | 05:21 PM
luke19790_3
£380 from boostmonkeys, sounds goods .
Old Jan 3, 2012 | 05:33 PM
wedge07's Avatar
wedge07
Y do i need a lambda sensor n why are they so much? Ecu sounds all good lol. Do they just plug straight in and what exact ms ecu i need
Old Jan 3, 2012 | 05:46 PM
luke19790_3
cheaper than a new engine tells you the air/fuel ratio
Old Jan 3, 2012 | 05:47 PM
luke19790_3
looking at that website the OFAM plugs into a EFI loom
Old Jan 3, 2012 | 06:00 PM
wedge07's Avatar
wedge07
I get ya as im tuning it myself. But i have an air/fuel ratio gauge off my o2 sensor? Or is the one ur on about more accurite?
Old Jan 3, 2012 | 06:10 PM
wedge07's Avatar
wedge07
Old Jan 3, 2012 | 10:39 PM
luke19790_3
something like this
http://www.ebay.co.uk/itm/AEM-GAUGE-...item45eff60fa0
Old Jan 4, 2012 | 07:05 AM
Rogeyboy's Avatar
Rogeyboy
You just need an AFR gauge to get an idea of how the engines fuelling whilst your mapping it.
The OFAM from boostmonkeys plugs into the EFi loom, direct plug and play (other than a vacumn line into the ecu) its £380 and will come with a basemap to get your car started and idling to a degree.
Map it yourself using "tunerstudio" its easy enough to get to grips with.
Old Jan 4, 2012 | 06:02 PM
wedge07's Avatar
wedge07
Its settled then. Thats my next route. Only problem is i dont know what sort of psi i can put through mine without blowin summat up. Lol what sort of power can these take? Eg ofab can take 250ish?? And does this control boost control?
Old Jan 4, 2012 | 06:03 PM
wedge07's Avatar
wedge07
Basicly i dont wanna spend 380 on a new ecu if ofab is decent n if i wont be able to tell difference?
Old Jan 4, 2012 | 06:27 PM
luke19790_3
The only thing will limit things is the injectors, turbo,engine etc.
With megasquirt and omex you can make changes with the laptop and fault find.
Old Jan 4, 2012 | 06:29 PM
luke19790_3
Don't think you can compare ofab and megasquirt
Old Jan 5, 2012 | 06:31 PM
wedge07's Avatar
wedge07
lol megasquirt it is then. im goin green on my injectors n riddin of the beiges n engined tuned up alot. its just the t3 needs goin bigger
Old Jan 5, 2012 | 07:52 PM
Rogeyboy's Avatar
Rogeyboy
Standard bottom end won't like much more than 230-240bhp... You can easily achieve that with OFAM and the correct turbo and injectors
Old Jan 5, 2012 | 08:13 PM
mattcroft's Avatar
mattcroft
Is the www.rsbible.co.uk website no longer up? That had a step by step guide using an efi xr3i loom and ofac with no amal valve, frst ecu and MAP. A few searches on google may help. Good luck
Old Jan 6, 2012 | 03:06 PM
wedge07's Avatar
wedge07
I have a lightened n balanced bottom end. Forged pistons n steel rods so ill be fine haha. I used rs bible too. Ill stick with ofab for time being as its better than ofac. Then upgrade to ms. What turbo do u reckon i should go for?
Old Jan 6, 2012 | 07:54 PM
mattcroft's Avatar
mattcroft
Deffo upgrade the management if you're spending.
As for turbo, a hybrid T3 garrett i'd suggest. I highly recommend AET in Wakefield, Andy Nicholls is excellent.
Old Jan 6, 2012 | 08:08 PM
wedge07's Avatar
wedge07
got a hybrid t3 on now bud and its already been tuned. its running 206 bhp at 15 psi but i want a bit more without upping the boost what other turbo choice have i got? and injector wise its going to have to be 803s
Old Jan 7, 2012 | 09:19 AM
mattcroft's Avatar
mattcroft
Best off talking to professionals (and i'm sure plenty of the people on here!), someone local to you or as I mentioned AET who I've had experience with, www.aet-turbos.co.uk
Old Jan 7, 2012 | 09:43 AM
luke19790_3
what hybrid turbo is it? stage 2,3?
Old Jan 7, 2012 | 10:31 AM
wedge07's Avatar
wedge07
I got told its stage 3 when bought it but i dont know much about turbos yet. Lol
Old Jan 7, 2012 | 11:33 AM
luke19790_3
keep if its a stage 3, get the boost turned up after changing the injectors.
Old Jan 7, 2012 | 12:35 PM
wedge07's Avatar
wedge07
A quick question if i put my foot down it flies up to 15 psi and then drops to 14psi? What psi do i class it as running at? And wat sort of boost can i up it too?
Old Jan 7, 2012 | 04:49 PM
Rob_DOHC's Avatar
Rob_DOHC
You would probably say it peaks at 15 and holds 14.
Old Jan 7, 2012 | 05:47 PM
luke19790_3
you need to upgrade your injectors first
Old Jan 8, 2012 | 12:28 AM
wedge07's Avatar
wedge07
Yeah exactly that so is it classed as boostin at 15psi?
Old Jan 8, 2012 | 05:33 PM
Rob_DOHC's Avatar
Rob_DOHC
I'd personally say it holds 14.
