Help with EFI conversion
Old Dec 27, 2011 | 09:40 PM
kermitt's Avatar
kermitt
Default Help with EFI conversion
How have you guys sorted your induction system as I noticed the K&N cone off my metering unit does not fit?
Now that the metering unit has been removed how is the fuel return plumbed in?
Also what to do with the vacuum hose to the brake servo? Do I need an FRST one?
Old Dec 27, 2011 | 10:27 PM
mentalasanything's Avatar
mentalasanything
Hello mate,
Induction wise, I've gone for a Cosworth Group A cone filter and trumpet to fit a T3 turbo and fitted it on to the hose that went from the Turbo to the metering unit.
Fuel system goes:
Fuel filter > fuel rail > fuel pressure regulator > fuel return pipe
Brake servo pipe I've used an XR3i EFi pipe. But you can use any silicone hose suitable to draw a vacuum and use the original fittings and fire trap.
Lee
Old Dec 27, 2011 | 10:31 PM
Rob_DOHC's Avatar
Rob_DOHC
As above matey, I used a fiesta rst vac pipe though. A cosworth cone filter will fit. Just remember the fuel return goes on the regulator not the end of the fuel rail.
Old Dec 28, 2011 | 03:17 PM
martinmilne's Avatar
martinmilne
Cosworth filter and makes it chatter lovely
Old Dec 28, 2011 | 06:33 PM
studabear's Avatar
studabear
you can use a mfi filter by using a part from a xr3i mfi metering head pipe
Old Jan 21, 2012 | 01:24 PM
kermitt's Avatar
kermitt
Well I picked this from Matt Lewis and I can't get it to fit;
http://www.mattlewismotorsportonline...?productid=338
cannot get a decent grip of the trumpet when fitted in the hose it just keeps popping off. Have tried three different clamps now of varying width and still no joy.
Tried cutting my boost hose to make it fit but the filter is so dam big!
What hose does everyone use cos I probably just cut up a perfectly good hose.
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
