0fac ecu with 0fab map sensor?
thanks,
is there any aftermarket map sensor that i can use?
you wrote that i can use small turbo escos, can you show me exactly how does it look like and what is the part number?
thanks
thanks
the small turbo escos one looks just the same as the ofac one but i doubt that its the same part number if i get a chance ill nip the garage and check the part number in a bit.
