Wheel Size / Offset help needed
Old Nov 18, 2011 | 01:46 PM
JK12's Avatar
JK12
Default Wheel Size / Offset help needed
Hi Guys.
Im looking at a set of Comp TH for my escort rs, however they are on my mates Pug at the moment which is ok as know they will fit, but my question is they are 15" x 6J and offset of ET15.
Now i know its smaller than the standard 15" x 7j but think that will be ok, but if i put 20mm spacers on will that be ok to match the ET35 offset that i need?
Cheers for any help - Jamie
Old Nov 18, 2011 | 06:39 PM
gus's Avatar
gus
et confuses the hell out of me
im sure the std wheel is 6x15 et 35
the et 15 wheel will be pushed right out from the hub (further from shock)
so adding a 20mm spacer will make them et-5
to make them et35 you would need to machine the mounting face down by 20mm
i could have this arse about face but someone will correct me im sure
Old Nov 18, 2011 | 07:33 PM
JK12's Avatar
JK12
Hi mate thanks for the reply! Yes me too, thought the spaded would sort it may have to give them a miss then!
Sure standard s2 wheels are 15 x 7j?
Old Nov 18, 2011 | 07:46 PM
phil_rs's Avatar
phil_rs
yam yammer
Standard s2 wheels are 15x6j with an offset of 36.5 to be precise lol! As Gus has rightly said, et15 will stick out like a bastard!
Old Nov 18, 2011 | 08:14 PM
JK12's Avatar
JK12
Thanks for the help lads, will leave them and get ford ones
Old Nov 18, 2011 | 09:28 PM
CHRISP's Avatar
CHRISP
this site can be quite useful mate, if you have the size of tyres, rim and offset it'll let you know how far in or out the new wheels will sit
http://www.rimsntires.com/specs.jsp
Old Nov 18, 2011 | 09:58 PM
RSmark84's Avatar
RSmark84
Standard alloys are 6.5J. Look for a set that is 7J
Old Nov 19, 2011 | 04:43 AM
JK12's Avatar
JK12
cool will look on that site mate cheers
yes will look out for 7s as well bud
Old Nov 19, 2011 | 08:40 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
ET15 will stick out the arches.
RockinRein
Aug 19, 2015 07:08 PM
col93saphcos
Aug 7, 2015 03:21 PM
Versus_Creations
24
Aug 5, 2015 09:32 PM
