Recharging problems??
Old Oct 24, 2011 | 12:24 PM
Scoti616's Avatar
Scoti616
Default Recharging problems??
right I've got to rewire my alt as the guy I bought the car from seriously
botched it, looks like a fairly new alt on my S2 it has a plug going into it
but then roughly soldered on is another wire going straight to battery??
should it go Alt>starter>battery? where do the wire go to on alt?
as you can tell I'm not electricly minded...dam keeps draining battery
now doing my head in:angry :
please someone help!
Old Oct 24, 2011 | 12:48 PM
studabear's Avatar
studabear
how thick is the wire? they are normally wired to the starter main feed lead, but if the wire is of adequate size it should be fine.
Does the batt light on the dash illuminate when ignition is switched on and go out when the engine is running?
have you checked the charge rate with the engine running?
Old Oct 25, 2011 | 09:11 AM
Scoti616's Avatar
Scoti616
ok had another look last night looks like I'm going to have to rewire things
and replace the conector block coming out of the alt,
as it look's a bit fkt
cheers studabear the wire is thick enough but there does not seem to be
a heat sheild protecting the starter motor prob why the last owner
run a direct line to battery from alt, I'm gonna try and get down to Lucas
today and get a new connector block.
Old Oct 28, 2011 | 04:22 PM
scrubby--rs's Avatar
scrubby--rs
Where in the uk are you Mate I got that part of the loom in my garage your more than welcome to it
Old Oct 31, 2011 | 09:30 AM
Scoti616's Avatar
Scoti616
ace scrubby I'm waaaaaaaaaaaay up in Aberdeen
i can pm you my home address if your willing to send it
i'll send you ŁŁ??
Old Nov 1, 2011 | 11:18 PM
scrubby--rs
Just pm me adress and I'll send it mate
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
