S2 non starter if left too long
Old 10-08-2011, 11:16 AM
EoinXR3
EoinXR3's Avatar
Default S2 non starter if left too long
Hi, i have a s2 which if you went to it in the morning would offer to start but never totally fires up and then nothing!
It will bump start and once its been running it will keep starting all day. The spark at the plugs is there although it arcs around the tip but not directly between electrodes. Has had new dizzy cap, rotor arm, plugs, leads, changed coil.
I bought it as a project with this problem, could it be the dizzy itself?
any help much appreciated
Old 10-08-2011, 01:18 PM
bigryrs
RSHoleinator
bigryrs's Avatar
Try a dizzy and see! all the rst stuff is that old it could be anything mate! good luck
Old 10-08-2011, 01:20 PM
darrenb16two
darrenb16two's Avatar
Youve check the battery & starter i take it?
Old 10-08-2011, 02:00 PM
EoinXR3
EoinXR3's Avatar
battery and starter are fine, it wont fire up, if i use a little starting fluid it'll fire up on it and then you can stop it and it will start again fine, its just the first start of the day
mjonathan24
29-10-2015 10:39 PM
A.t.p
23-10-2015 07:54 PM
sridgett
01-10-2015 07:30 PM
Fudgey
21
30-09-2015 06:19 PM
Fil
30-09-2015 12:08 PM
Quick Reply: S2 non starter if left too long
