Front drivers side wheel
Old Feb 13, 2005 | 04:38 PM
H71 RBO's Avatar
H71 RBO
Default Front drivers side wheel
Guys, my front driver's side wheel on my S2 RST, is squeeking and banging when driving. It gets worse when I break....! Had the wheel off cleaned all the breaks etc etc
Any idea's what it is and how I can sort it?
Old Feb 13, 2005 | 09:58 PM
K18NEO's Avatar
K18NEO
could be the stearing rack bolt loose? check that!
or .. i dont know
Old Feb 14, 2005 | 05:25 PM
Moonie's Avatar
Moonie
Take the wheel off and check everythig is tight - bottom ball joint, inner tca bolt, arb nut, track rod end, shocker pinch bolt, caliper bolts etc..
Also with the vehicle jacked up under the body try to move the wheel in/out at the top/bottom and also at the sides. If you feel movement get someone to have a look where the movement is coing from.
jessie_rs
11
Jun 3, 2019 04:57 PM
C2 MAK
Aug 20, 2015 09:46 PM
djmca
Aug 20, 2015 08:26 AM
Palethorpe01
15
Aug 18, 2015 06:09 AM
RIB1122
Aug 12, 2015 08:51 PM
