Replacing Rear Chassis Rails?
Old 26-07-2011, 03:18 PM
mattseries2
mattseries2's Avatar
Default Replacing Rear Chassis Rails?
Anyone done this?
Mine have had some proper bodges done on them and after cutting it out im abit worried that this will be a week point now.
Can you still buy the double skinned ones from panel shops?
What they like to change? I see that the rear tie arm mounts weld to them. Will i need new ones to weld onto the chassis rails?
Old 27-07-2011, 04:47 PM
beaver rs 88
in the garage
beaver rs 88's Avatar
hi mate ive got to do these on mine ive bought the complete rails not the skins as thats just covering old rust and will be the same in a few years. not got round to doing them yet as ive lost all motivation. looking at them youl have to drill them out from the top but i got told to measure the original ones before i remove them so the new ones are in the correct position. hope this helps.
Old 27-07-2011, 07:01 PM
mercury grey minter
mercury grey minter's Avatar
I did mine a few years back.You need to drill out the spot welds from underneath,drill new holes in the replacement rails then mig them in place.Only cut out what is rotten.My repacement rails were around 3 feet long but only had 1&1/2 feet of rot to cut out.
Old 27-07-2011, 07:38 PM
mattseries2
Beaver where u get the rails from, I'm struggling to get hold of them??
Old 27-07-2011, 11:11 PM
beaver rs 88
in the garage
i got them from my local panel shop they had to order them in and they wernt cheap try Ł90 a side
Old 29-07-2011, 04:15 PM
Rob_DOHC
Rob_DOHC's Avatar
You can get them from hardrian auto panels,
Here
http://hadrian.dominohosting.biz/hadrian/hcpdb01.nsf/PartNoDocID%2F3F00FEF54D19B58F8025759D00780175!Edi tDocument&Ret=ALL
Rob,
Old 29-07-2011, 04:16 PM
Rob_DOHC
Rob_DOHC's Avatar
I personally would suggest replacing the sections that are bad, so cut the rot out and slot in a cut down section from a whole leg.
Rob,
Old 29-07-2011, 05:57 PM
mattseries2
That's what I was thinking of doing but how would you weld the inner leg to it's self as it would be boxed in?
Old 29-07-2011, 09:12 PM
Rob_DOHC
Rob_DOHC's Avatar
Theres only one section thats double skinned, cut out the double skinned section and replace that part. Or, if you chassis leg has gone you will have a rusty line in the boot under the side trim panels, give it a gentle poke and you'll have a nice hole to weld through
Rob,
Old 30-07-2011, 04:39 PM
mattseries2
Typical the bit that ive cut out is double skinned!! Ł90 a side is pricey but its to much hassle to fabricate it from scratch.
Old 30-07-2011, 05:02 PM
jamie rst
jamie rst's Avatar
I got some patten ones for mine though my work place and they was fine to fit but at least you know its good and strong when done and i think i paid Ł72inc vat for both sides, mind that was 3 years ago lol, sure i seen some on ebay the other day as well
Old 30-07-2011, 09:45 PM
mattseries2
Jamie - my mate said he also saw some on the bay. Will have a look.
Gaz 88
Ford Focus RS Parts for Sale.
29
10-05-2017 12:31 PM
SmudgerByName
52
28-07-2016 06:14 PM
3i Jim
20-11-2015 05:12 AM
155lee
14-08-2015 11:21 AM
Quick Reply: Replacing Rear Chassis Rails?
