Coilover Fittment help please..
Old Jun 23, 2011 | 07:36 PM
fastash1's Avatar
fastash1
S2 sold :(
Default Coilover Fittment help please..
Hi all,
I am fitting gaz coilovers to my s2. The issue I am having is that the rear spring is touching the inside of my rim. I am very confused..
Any help would be greatly appreciated..
Thanks
Ash
Old Jun 23, 2011 | 07:43 PM
adam151082's Avatar
adam151082
what wheels do you have? possibly to wide as the coilovers will be wider than the standard shocks.
Old Jun 23, 2011 | 07:46 PM
fastash1's Avatar
fastash1
S2 sold :(
hi
yes prob should have said i am running rs7's with 195/40 tyres..
Old Jun 24, 2011 | 07:09 AM
Rogeyboy's Avatar
Rogeyboy
Have you strengthed the rear shock turrets? They can break if the take the force of the cars weight on them, GAZ do a kit with rear spring adjusters so the spring remains on the lower arm. So you get adjustable shocks in the normal place and the springs are height adjustable in the normal place too...
Old Jun 24, 2011 | 07:16 AM
stuart collins's Avatar
stuart collins
the shock is wider as the spring s on it, u will have to run a 5-10mm spacer to clear or put rear disc conversion on that will space them out a bit
Old Jun 24, 2011 | 07:28 AM
jonny s2's Avatar
jonny s2
as above, you will need a spacer 10mm atleast, my RS7 diamond cuts still touch with rear disc conversion, so spacer is needed
Old Jun 24, 2011 | 12:55 PM
tasos77's Avatar
tasos77
rs turbo from Greece...
I used 5mm spacers, and they don't touching anywhere, i also have rear disks
Old Jun 24, 2011 | 07:35 PM
luke19790_3's Avatar
luke19790_3
who told you that?? about the turrets
Old Jun 25, 2011 | 05:42 AM
zippyobrien's Avatar
zippyobrien
I'm strenghtening my turrets also, as there desinged to only take the shock there not strong enough to take wieght of car.
Old Jun 25, 2011 | 10:38 AM
luke19790_3
didn't weld mine, but i don't plan on taking 4 people in the car
Old Jun 25, 2011 | 11:39 AM
jonny s2's Avatar
jonny s2
i read somewhere before they dont really need welding
Old Jun 25, 2011 | 12:13 PM
muz's Avatar
muz
Wye Valley Hardcore
They don't need strengthening. It's just what coilover companies say to cover their backs but a strut brace is advised. Tony at 909 sport has been rallying his RS1600i for many, many years with no turret mods and never had a problem.
Old Jun 25, 2011 | 01:11 PM
zippyobrien
Seam welded my whole shell as I imagine the 909 one would have been
Old Jun 25, 2011 | 10:14 PM
rs combi's Avatar
rs combi
ive got them on mine with 17" comps with 205/40's and they dont touch
Old Jul 19, 2011 | 07:29 PM
fastash1's Avatar
fastash1
S2 sold :(
Hi all, just a little update on these as i am stil having trouble with them, i had to put my old suspension back on to go to RSOC combe.
The issue i am having is that i am now running 8mm spacers which has pushed the wheels out too far into the outside of the arch!!
Also i have set the hight approx 1-2" above the tyre but cannot have people in the rear and when i go round islands it scrubs the arch
I am really stuck with these and feel very disapointed with the Gaz kit. My old Konis which are leaking and fubard are still better than this kit..
My setup is Rs'7 with 195/40 and 8mm spacers..
Old Jul 19, 2011 | 07:56 PM
luke19790_3
did you have rear discs?
Old Jul 19, 2011 | 08:24 PM
fastash1's Avatar
fastash1
S2 sold :(
nah i dont,still have standard rear brakes
Old Jul 20, 2011 | 11:27 AM
luke19790_3
i've got the gaz kit on mine, but i've got discs on the back which adds a few mm.
you could have the arches modified
Old Jul 20, 2011 | 02:33 PM
RSandy's Avatar
RSandy
iv got the exact same issue!
as standard the top hats on my coilovers were too long, and with the car lowered to how i wanted it, they bottomed out on the shock body. made up custom top hats
my 17x7.5 MO's catch the springs, so im running 5mm spacers and rear discs, but the wheel is pushed so far out that the tyres no scrub the arches terrible! and thats with the arches already rolled and welded up flush!
also, how the hell are people running rear strut braces? as i cant see how the bolts for the rear strut brace can go thru the turret without fouling on the coilover unit on the other side, as its a fuckin tight fit in there!
also, i refuse to raise the car, as i want it low, which is why i bought coilovers lol so no people telling me to raise it please. im so adament to try and make this work, im even currently trying to source 185 35 17 tyres!!
jessie_rs
62
Aug 6, 2019 09:27 PM
mk1turboestate
Dec 2, 2015 08:31 PM
S3an
Sep 26, 2015 11:39 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
S3an
13
Sep 13, 2015 10:01 AM
