CVH Cylinder Head
I'm suspecting that my RST cylinder head has a crack somewhere because I keep hearing bubbles of water after I switch off the engine until it cools down, even though I've got the swirl pot.... which means compression is leaking from somewhere.
I found a 1.9 CVH (USA) modified cylinder head for a bargain. Is this the same as the 1.6 CVH head? If not what differences does it have? Thanks
No not losing any water. But I once heard that with a swirl pot you shouldn't hear those bubbles anymore. Could it be because of the extreme hot mediterranean temperatures of my country then?
However, will the 1.9 CVH (USA) head fit on my 1.6 CVH block? Thanks guys
I've had some boiling issues after shutting the engine in the summertime. Are you sure that your cooling system is handling the pressure? Is the expansion tank cap up to it?
