help! help!
Old Apr 1, 2011 | 06:31 PM
steve120283's Avatar
steve120283
Default help! help!
hi just fitted a new engine in my escort rs turbo first gear turbo kicks in, 2nd ,3rd, 4th gear is not holding the power (flat) as if its holding back any advice would be great?
it has a t3 turbo accuator and boost valve the car anay one had the same problem
Old Apr 1, 2011 | 06:52 PM
steve120283
Default help please
any help with this problem will be great
Old Apr 1, 2011 | 07:03 PM
essexRSTSouthend's Avatar
essexRSTSouthend
is she chipped?
liam-rst's Avatar
liam-rst
shit happens
make sure u have no air/boost leaks from any of the pipes, are u still using the amal valve?
Old Apr 1, 2011 | 08:10 PM
steve120283
think she is chipped (rs collins 200bhp)
Old Apr 1, 2011 | 08:18 PM
steve120283
I still use the amal valve but screwed closed at the min, but when opened it drives ok but when I slow down it cuts out
Old Apr 1, 2011 | 08:48 PM
matthewsimone's Avatar
matthewsimone
Old Apr 1, 2011 | 09:34 PM
PETEDUDE007's Avatar
PETEDUDE007
get her setup!? FUELLING MAYBE!?
Old Apr 2, 2011 | 01:14 AM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Take it to someone that know's what they're doing?
Old Apr 2, 2011 | 01:49 AM
sean_rsts2's Avatar
sean_rsts2
addicted to boost
actuator possibly
Old Apr 2, 2011 | 06:13 AM
essexRSTSouthend
Cuts out? Does it idle ok?
Old Apr 2, 2011 | 06:20 AM
essexRSTSouthend
May sound like a stupid thing to say,but run a bleed valve and see if it does the cut out still.using a bleed,make sure you got a boost gauge so you dont run stupid boost.
Your amal valve shouldnt have a screw of any kind on it.all hoses should flow air.wish i could help more on the amal valve but ive never had one since owning a rs.
Old Apr 2, 2011 | 08:20 AM
Rob_DOHC's Avatar
Rob_DOHC
I think his thing with the screw IS his bleed valve.
Take it to someone who knows what they are doing, before its too late. Is this a NEW NEW engine? if so try running it in.
Old Apr 2, 2011 | 09:54 AM
steve120283
yes she idles fine
Old Apr 2, 2011 | 01:31 PM
steve120283
aney one got dump valae and boost diagram
