Changing Coolant
Old Mar 30, 2004 | 04:55 PM
Default Changing Coolant
Hey,
quick question:
to drain the coolant i have to disconnect the bottom hose right? There isn't a draining plug on the s2 (1990) is there?
Old Mar 30, 2004 | 05:11 PM
chewyS2RST's Avatar
chewyS2RST
yeh take the bottom hose off the rad or from the water pump,
if you have access to a hose its always worth while flush the engine through.
Old Mar 30, 2004 | 05:17 PM
just drain the coolant then blast water through using a garden hose yea?
does it flush it doing that then? suppose as long as you seal the hose against the coolant hose it has no choice!
Old Mar 30, 2004 | 05:54 PM
Rich's Avatar
Rich
Spot on mate
Old Mar 31, 2004 | 05:06 PM
chewyS2RST's Avatar
chewyS2RST
yep drain it out push the hose back on then just refil then empty a few
times,as if by magic engines flushed out!!
Old Apr 5, 2004 | 12:26 AM
how do you bleed air out of the system once refilled?
ive been letting it idle with the cap off until no more bubbles appear in the header tank
also now my heater only blow cold air no matter how hot the engine is
therea no blockages in the matrix i diconnected one end at a time while it was running and water pumped out fine
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
marky_g
Sep 12, 2015 04:26 PM
