S2 plug gaps
Old Jan 25, 2011 | 02:15 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
Default S2 plug gaps
Right i am in a quandry as my car is juddering slightly at around 30 mph in 3rd and 4th gear plugs are denso iridium ik24 with a group a coil and magnacor leads i have set the gap to what it says in the manual but the slight judder is still there shall i make the gap smaller say 0.6mm??? any help would be greatful
cheeRS
Old Jan 25, 2011 | 02:26 PM
studabear's Avatar
studabear
What condition is the distributor cap and rotor arm?
Are you convinced this judder is ignition related?
Old Jan 25, 2011 | 03:41 PM
milesy23rst
PUG 306 GTI-6
Yes stu as everything else has been checked and also the timing is spot on as is the fuelling, rotor arm is new as is the cap
Old Jan 25, 2011 | 05:56 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
you could try to make the gap smaller won't hurt, if it doesn't go away check the leads.
Old Jan 25, 2011 | 06:14 PM
milesy23rst
PUG 306 GTI-6
Ok matey will try them at 0.6 and see what its like if not i will get rid of the magnacor's never used them before as always use genuine ford or motorsport leads
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
