Servo upgrade
Old 19-01-2011, 12:20 PM
c123s1turbo
c123s1turbo's Avatar
Default Servo upgrade
Hi, I will need to upgrade my servo at some point before the engine gets done. Been looking at replacing the servo with somthing better. Has anyone done similar? For an example burton have in their new catalog on page 128 a brake bias assemblies. They bolt in place of the servo an have 2 cylinders would that be any good? Seem like a straight forward swap any advice or help would be great. Tel
Old 19-01-2011, 12:36 PM
Zetec_mk4_XR3i
Zetec_mk4_XR3i's Avatar
hi mate, never seen one on a mk4 yet but the lads on xrtwo.com are using mk2 mondeo servo's on their XR2's etc with good results. The Mondeo ones are a good size too.
I'd imagine if they fit a mk2 fiesta they can be made to fit a mk4 Escort - more of a budget upgrade but worth a look.
Old 19-01-2011, 12:50 PM
Mk1 Mex
Series One
Mk1 Mex's Avatar
I was thinking about this last night, think someone needs to do a "HOW TO" on converting to a Mk2 Mondeo servo etc..
I might have a crack at it over next winter cant be ar$ed this year..
I think it needs to be turned upside down, but dont hold me to that...
Old 19-01-2011, 12:59 PM
c123s1turbo
Ok that's somthing to look into. I have a s1 should have out that in the post
Old 19-01-2011, 03:42 PM
s1cab
s1cab's Avatar
compbrake also sell a pedal box that bolts on in place of the original servo and master cylinder Ł150 iirc.
Old 19-01-2011, 05:08 PM
c123s1turbo
S1 cab
Does that mean I would have to have my brake clutch an gas pedal changed to fit that tho?
Old 19-01-2011, 05:58 PM
Oranoco
Oranoco's Avatar
iirc pedal boxes do away with a servo altogether which means althought th efeel is very good they are exceptionally heavy in use. As I guess half the reason you want to change the servo is to enable less effort to be expended when pressing the middle pedal
Old 19-01-2011, 06:15 PM
c123s1turbo
Main reason for the change is the servo has a leak. With the engine turned off you can hear a hiss coming from the rear of it. They are getting hard to find now and don't really want to replace it with a second hand one. Does any have another suggestion? Are repro
servos available?
Old 19-01-2011, 06:21 PM
orionmojo
orionmojo's Avatar
Try a Renault Scenic servo. They are similar but are abit bigger in size.
http://cgi.ebay.co.uk/Renault-Scenic...item2a066f484c
I havent tried this myself yet, but i do have one in stock to try one day. It might be worth a chance. Certanly more readily available than a std item anyway.
Old 19-01-2011, 06:47 PM
c123s1turbo
Ok cheers mate another thing to look into. Il be looking into changing the servo and the master cylinder as well
Old 19-01-2011, 08:35 PM
s1cab
s1cab's Avatar
Originally Posted by c123s1turbo
S1 cab
no you dont need to touch your pedals.
Old 20-01-2011, 01:08 PM
Mk1 Mex
Series One
Mk1 Mex's Avatar
Been a bit quite a work today so have been having a hunt around on the old interweb and have come across this site http://www.mwstewart.co.uk/articles/mk3mondeomc/ , however i cant read it clearly here at work as the text is all bunched together. Can one of you guys have a look and see if it will help out on the servo upgrade.
I know its detailing how to do the conversion on a Mk3 Fez but most be some similarities.
Old 20-01-2011, 09:23 PM
project rs
project rs's Avatar
rob dohc has done a thread on this with pictures through the whole process
https://passionford.com/forum/ford-e...on-inside.html
Old 22-01-2011, 08:57 AM
Rob_DOHC
Rob_DOHC's Avatar
Lol, was just about to post the link, cheers mate got a few more pics that i can add if any one need more.
Rob,
Old 22-01-2011, 02:02 PM
c123s1turbo
cheers mate, think thats the sort of thing il do. gone off pedal boxes now, heard they are a bit over kill for a road car
Old 24-01-2011, 11:14 AM
c123s1turbo
Does a s2 servo fit a s1?!
Old 25-01-2011, 02:09 PM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
break out a welder and a mondeo servo, i've converted loads of mk2 fiesta's to them now with all good results.
you do need to remove the servo mounting brackets and chop a bit out and reweld, then open up the mounting holes witha burr or similar.
takes about an hour i reckon all in.
granted this is on a mk2 fiesta, but mk4 escort servos are a direct fit to them, so vice sresa it should be the same process.
Old 25-01-2011, 02:42 PM
Rob_DOHC
Rob_DOHC's Avatar
Doesn't take long. Havent used it yet tho lol.
tankybaby66
06-02-2016 02:24 PM
stevecfrst1
30-09-2015 05:18 AM
Sp3no
27-09-2015 07:23 PM
focus2351
09-09-2015 09:33 PM
Quick Reply: Servo upgrade
