Heated screen issues
Old Jan 2, 2011 | 04:21 PM
marc_gti's Avatar
marc_gti
Default Heated screen issues
Hi Guys
Having problems with my front heated screen.
I had the screen changed around 6-8 months ago when it came back from being painted and its never worked since
I have checked the 2 contacts either side of the windscreen and also checked the earth point at the top behind the clock and they are all fine.
Also i have noticed that the light on the switch itself lights up when its pressed. i am stuck now and not sure what to do next
Any ideas? and does anyone happen to have a diagram of the fuse and relay locations in the fusebox and under the steering column
cheers in advance
marc
Old Jan 2, 2011 | 04:43 PM
project rs's Avatar
project rs
have you had a mulit meter on the wires or just checked to see if they look attached
Old Jan 2, 2011 | 05:10 PM
marc_gti's Avatar
marc_gti
only checked if they are attached, i have had a play around and they are certainly not loose
Old Jan 2, 2011 | 05:58 PM
martysmartie's Avatar
martysmartie
First thing you need to do is to check whether you have power WITH the screen on at both sides, if you do then the screen itself is faulty. If not then you can work your way back from there.
Martin
Old Jan 2, 2011 | 06:03 PM
marc_gti's Avatar
marc_gti
ok thanks, so on a multimeter what setting do i need? and im guessing i use one side at a time as the positive and then use the top earth point as the earth?
Old Jan 2, 2011 | 06:05 PM
martysmartie
Yes on the meter you want to set to 20V on the "DCV" range it usually goes 2 then 20, with the screen on and so engine needs to be running as well put a probe on each wire, it doesn't matter which is which, you should get a reading of 13V +.
Martin
Old Jan 2, 2011 | 06:06 PM
marc_gti's Avatar
marc_gti
Cheers fella, will try this tomorrow and report back my findings
Mark_
14
Jan 16, 2016 05:27 PM
SMILER258
Sep 28, 2015 09:04 AM
cossie09
Sep 10, 2015 06:56 PM
