help please
Old Nov 5, 2010 | 12:35 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
Default help please
a mate of mine has had a go at rebuilding my turbocharger,ive refitted it and i have no boost atall!!!
when my rs turbo is revved hard at a standstill ,should the actuator arm move?
what actually makes the actuator arm move? ecu? boost pressure created from the turbo?
cheers
Old Nov 5, 2010 | 12:40 PM
adduk's Avatar
adduk
I dont think it should no.due to you not building up and boost under load.
Old Nov 5, 2010 | 01:44 PM
rickbartlett
G911 TTA
i was sure that if reveved hard it would ,as otherwise the dump valve wouldnt dump?
my car is not boosting at all
Old Nov 5, 2010 | 03:46 PM
rickbartlett
G911 TTA
bump
Old Nov 5, 2010 | 04:33 PM
craig rst kid's Avatar
craig rst kid
whats it like underload
Old Nov 5, 2010 | 04:35 PM
rickbartlett
G911 TTA
no boost at all ,just a small whirling noise comin thru the turbo,but not a tiny bit of boost,
it ent the end of the world as a mate has a turbo for me but just thought id post on here about it
Old Nov 5, 2010 | 04:41 PM
conor.rst's Avatar
conor.rst
Have you got a boost gauge ? and have you put load on the acctuator when you set it up ?
Old Nov 5, 2010 | 08:52 PM
rickbartlett
G911 TTA
yeah have boost gauge mate,wont go above zero,and actuator was pre-loaded.think it must be a problem with the turbo wen we built it back up
Old Nov 5, 2010 | 09:49 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Are you judging the performance of this turbo by what its doing when you free-rev it?
The actuator won't even begin to move until it see's at least 6 or 7 psi (depending on what actuator it is), meaning that you'll never see it move except on a dyno. The turbo also won't register much above zero whilst free-revving.
That said, DIY turbo rebuilds always fascinate me. Why on earth would you gamble with something so fundamental to your engine? If the turbo shits itself, chances are your engine will be toast, so why chance an unbalanced DIY rebuild?
Old Nov 6, 2010 | 07:54 AM
rickbartlett
G911 TTA
no,it makes no boost when driven.
well a mate has offered me his turbo,but i havent got it yet,so i bought a small rebuild kit dirt cheap and we just thought it was worth a go,thats why we attempted it.it didnt work but it ent the end of the world,at least we had a go.i live on a proper budget so cant afford to just go out and buy a new turbo unfortunately
