Is it a tall block?
Old 28-10-2010, 11:01 PM
  #41
s2chris
s2chris's Avatar
cheecky how they do it,but who would no that has just read the basics and got them to build it,shocking that companys get away with it,but theres plenty out there that do it.
Old 29-10-2010, 01:54 AM
  #42
rsmark86
rsmark86's Avatar
well if my engine lasted 2k and i spent 3k doing it they would replace it i know that for sure lol
Old 29-10-2010, 07:20 PM
  #43
Canada1
Canada1's Avatar
Hi Grant XR,
Can you measure the diameter of the piston?
This will tell if you have a +2mm overbore ( or more)
Old 29-10-2010, 07:52 PM
  #44
s24bigbhp
s24bigbhp's Avatar
them pistons are from specialised engines they are called zolna pistons mine had the same code on them
Old 29-10-2010, 07:55 PM
  #45
Canada1
Canada1's Avatar
What size are the "zolna" pistons? 80mm or 82+ mm?
Old 29-10-2010, 09:26 PM
  #46
s24bigbhp
s24bigbhp's Avatar
if i rightly remember the piston itself was 82+ they cost me £160 each. price way too much the quality wasnt that good aswell looked like cast there definatley specialised engines in grays essex the piston rings are made by hastings usa
Old 29-10-2010, 10:21 PM
  #47
muz
Wye Valley Hardcore
muz's Avatar
I had a "Stage 3 2.0 Zetec" they built which was the top spec they did without going into forged rods and high compression pistons. This was thier "fully gas flowed and ported head" which I always thought was a little rough for an engine which wasn't exactly cheap!
good job it had these to force the air in
Old 30-10-2010, 06:22 AM
  #48
s1cab
s1cab's Avatar
Old 30-10-2010, 09:24 AM
  #49
RSricRS
Long live the ford RS'S
RSricRS's Avatar
Originally Posted by rsmark86
gutted i paid 1500 for my engine and has only done running in miles and is a proper built cvh..... so always best to shop about....
i was going to just pay a company to do a standard rebuild but for half the price i brought a proper cvh....
to be honest mate if you want a good engine i wouldnt bother with a zvh i would either do a big spec cvh or go full zetec turbo as the zetec is the same price as a zvh and is a much better conversion
Not being funny mate, but are you saying a zvh isn't a good engine.
Old 30-10-2010, 09:27 AM
  #50
grant_xr
grant_xr's Avatar
Unhappy
Originally Posted by Canada1
Hi Grant XR,
Yeah they are 82mm mate, so it is a bored out 1.8
Old 30-10-2010, 12:39 PM
  #51
Daveysaff
Skint Passionford User
Daveysaff's Avatar
Its not that the ZVH is a bad engine, its just thats a good ZT will make more power for similar money! Especially if you're building from scratch.
And a zetec block is designed to work with a zetec head, not a cobbled together mismash of two engines
IMO
Old 30-10-2010, 05:15 PM
  #52
Canada1
Canada1's Avatar
Wow!
The way those "stage 3" 2.0 zetec ports look like,( a little rough to say the least ) a CVH head would probably flow the same.
Old 30-10-2010, 08:13 PM
  #53
marky_g
Fleet Manager
marky_g's Avatar
im pretty sure they used to import all there 1900 cvhs (they used to say on there site that there not over bored 1800s) well thats what ian the owner told me a few years back
Old 30-10-2010, 11:35 PM
  #54
Canada1
Canada1's Avatar
Hi Mark,
I certainly hope that import USA or Canada blocks were used in the past.
The block shown in this thread is a 1800 UK block overbored.
Old 31-10-2010, 12:50 PM
  #55
JoshXR2
JoshXR2's Avatar
what casting marks on on a 1900 block?
Old 31-10-2010, 07:35 PM
  #56
Keenyzs
Keenyzs's Avatar
On the website they say its an 1850cc block bored to 1905cc, they use 82.5mm, 82.75mm, and 83mm pistons.
Old 09-11-2010, 10:15 AM
  #57
Rob_DOHC
Rob_DOHC's Avatar
Originally Posted by Rob_DOHC
Think my engine is costing £600-700 to build to a very high standard. lol a higher standard than specialised engines anyway!
Rob,
Sorry to resurrect this post, just thought i would mention my engine has in fact cost nearer to £1200, just finished ordering parts and thats using the standard cam! so £1500 with a cam kit. You could probably knock off 2-300 for unnecessary machining, and a further 1-200 if your standard bores are good.
Machining alone came to £430, gaskets, bearings and seals came to £200 from burtons.
Hope that helps some one when rebuilding their own engine! This also isn't taking into account the 12 or more hours it will take to measure up and blue print the bottom end or the time it will take to lightly port the cylinder head, so for a good spec high quality rebuild by a tuner i can easily understand the bills some people get. I would probably charge 2500-3500 grand for an engine to similar spec.
Rob,
gcfcos
59
06-10-2015 05:04 PM
Adam-M
Was It You?
01-10-2015 07:55 PM
AJC
01-10-2015 06:47 PM
20/20 vision
29-09-2015 11:27 AM
20/20 vision
28-09-2015 03:03 PM
Quick Reply: Is it a tall block?
