running lean under boost/load
hi im new to all this. i have just bought a 1988 rs turbo with zvh engine its running lean under load when adjusted it cuts out ht leads all look good will i get away with just changing the spark plugs fo the moment, what spark plugs, what gap should it have on the spark plugs help greatley appreciated thanks.
also where is the ecu located?? thanks again
with the running problems please dont try and set up your self if you dont know rst turbos , the best mod that can be done on these cars is a rolling road set up.
as you only in basingstoke ring power engineering in middlesex they will set it up for around 150 quid and will be like a new car
01895272111 tell ian that head with the s1 sent you
in my eyes hes the best guy for mfi equipped cars as no one else likes them and trys to sell you omex ect
it was at a rolling road where i was told i need to do this before he could do anything more he done the ignition timing but when he tried adjusting air fuel etc it was cutting out
Weird, have a look at your distributor cap and rotor arm too in that case.
Im the opposite mate (although im sure it will start a massive argument) Chris todd did a sterling job on my car, cost £100 and he never tryed to sell me any thing, in fact gave me some freebees
Rob,
Rob,
Eigdoog
13-09-2015 05:46 AM
