help
Old Sep 6, 2010 | 05:01 PM
diamondrst's Avatar
diamondrst
Default help
my heater switch has stopped working along with my rad fans and indicators anyone have an idea wot it could b cheers
Old Sep 6, 2010 | 05:29 PM
martysmartie's Avatar
martysmartie
Have you checked simple fuses first? If ok then move onto the relay for the fans and follow the same procedure for the indicators.
The fans would have a dedicated fuse I am sure as would the indicators and are totally independent of each other although don't know Escort electrics intimately.
Don't associate the two problems as it could just be pure coincidence both things have appeared at the same time as it sounds in this case it's two separate issues.
Also see if the indicator fuse protects anything else as it's not uncommon for it to protect two circuits, I.E reversing lights as well or it may well energize the fan relay as well.
Martin
Old Sep 6, 2010 | 05:37 PM
beaver rs 88's Avatar
beaver rs 88
in the garage
could be a dodgey earth mate, dont have a wiring diagram 2 hand but something 2 check.
Old Sep 6, 2010 | 06:08 PM
diamondrst's Avatar
diamondrst
indicators still flash wen i set the alarm checked all fuses none r blown and my loom doesnt look like it has melted
Old Sep 6, 2010 | 07:08 PM
drsrst2zvh's Avatar
drsrst2zvh
Definate earth check the 2 on the inner wings just below the back of the headlights and then check the one on the wiper motor mount.
Old Sep 6, 2010 | 07:36 PM
diamondrst's Avatar
diamondrst
wot could hav happened to them melted or snapped and r there only three
Old Sep 6, 2010 | 08:26 PM
martysmartie
The fact the indicators work with alarm show it not to be an earth problem!
Martin
Old Sep 7, 2010 | 06:59 AM
drsrst2zvh's Avatar
drsrst2zvh
My indicators still flashed when I bleeped my alarm however when I had my foot on the brake pedal and the inidcator on the indicator wouldn't flash. Also my heater fan wouldn't work when the wipers were going, all I did was clean all three earth that I said previously and he presto problems solved.
Old Sep 7, 2010 | 07:39 AM
diamondrst's Avatar
diamondrst
Mine wont work if i want to indicate my heater doesnt work or my radiator fans all earths are connected so i dnt think its that or everythin would b f**ked its only these 3 things that dont work could it b a relay
Old Sep 7, 2010 | 08:47 AM
craig rst kid's Avatar
craig rst kid
id say it woz a relay if uve checked everything else just make sure its not differen relays for the different things goin wrong m8 as marty smartie sed
Old Sep 7, 2010 | 08:58 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
yellow relay in the fuse board.
