clutch problem
Old Aug 31, 2010 | 06:35 PM
1strst's Avatar
1strst
Default clutch problem
while the car was off the road i changed the clutch and put a hydraulic clutch on removing the cable. But now the clutch is like an on and off switch there is no bite it just goes with a big jerk and then your off. The new clutch was a sasch i dont think there anything special any help on this asap will be greatly appreciated as when this is done it will be ready for the road again
Old Aug 31, 2010 | 07:41 PM
studabear's Avatar
studabear
is it bled properly so all the air is outta the system?
Old Aug 31, 2010 | 07:44 PM
chaffe's Avatar
chaffe
Turbocharging Technician
could be the pivot points for the master cylinder not being in an optimum position, or the master cylinder is not matced to the slave, i doubt its anything to do with the clutch.
Old Aug 31, 2010 | 08:05 PM
1strst's Avatar
1strst
thats what i was thinking i have ordered a different slave to match exactly so will give it a go when it comes
yes it is bled ok but i did double check it earlier to rule it out
Old Aug 31, 2010 | 08:14 PM
chaffe's Avatar
chaffe
cool, just a mate of mine put a hyd clutch on a mk2 golf and had a few similar issues, he had to fanny about a bit to get it to clear correctly.
Old Aug 31, 2010 | 08:26 PM
1strst's Avatar
1strst
what do you meen clear correctly
Old Aug 31, 2010 | 08:29 PM
faisal's Avatar
faisal
for some reason i had the same problemi changed the cable thinking that lol then i found it was the ratchet which i replaced cut it to fit perfectly and put a heavy duty adgustable clutch pedal which should last years and years lol im running a 4 paddle racing clutch it does jerk a bit in 1st gear which cures if u rev it a it more in 1st.. pm me if u need any help
Old Aug 31, 2010 | 08:30 PM
chaffe's Avatar
chaffe
opposite problem to you, not enough stroke on the slave, the clutch would drag and not clear to allow a gear change or get it into gear!
Old Aug 31, 2010 | 10:12 PM
Karlos G's Avatar
Karlos G
Balls Deep!
We are talking hydraulic clutch mate!
Sound like something is getting stuck maybe, got any pics of the conversion, master placement, rod to pedal, slave placement?
Old Sep 2, 2010 | 07:09 AM
1strst's Avatar
1strst
i pretty much copied the conversion on yours karlos but used a different slave so i will wait and get the different one and try that
yatta
May 21, 2016 10:31 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Rammer46
Sep 18, 2015 08:31 AM
talon1
Sep 15, 2015 10:27 AM
Flateric_2002
Sep 15, 2015 08:41 AM
