Speedo problem...
Old Aug 10, 2010 | 09:14 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default Speedo problem...
My speedo has stopped working (bounces up every now and then), and I can hear what I think is the cable turning round 'clicking' inside the speedo?!
The end of the cable is square so I'm thinking maybe the hole in the back of the speedo has worn not square, and so it's just spinning round inside catching every now and then?
Any one know if this is the case?
Cheers!
Old Aug 10, 2010 | 09:19 PM
mattseries2's Avatar
mattseries2
Are you sure its clipped in properly Karlos as i had this and found to not be pushed in all the way...also try gearbox end?
Old Aug 10, 2010 | 09:24 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah checked that, it was in as I had to squeeze the clip to release it, I'm guessing the gearbox end is in as I can hear what I think is it turning.
Old Aug 10, 2010 | 09:30 PM
mattseries2
Maybe the speedo is worn then...? Grab another one and giv it ago
Old Aug 10, 2010 | 09:31 PM
juffer's Avatar
juffer
I had this isue on mine not long back. i change the cable and it was fine.
Old Aug 10, 2010 | 09:34 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Hmmm I may have another speedo kicking around to try, at least if that doesnt sort it I know it's the cable!
Cheers Fella's!
Old Aug 10, 2010 | 10:09 PM
sean_rsts2's Avatar
sean_rsts2
addicted to boost
any of you lads know where i can get a 2 piece speedo cable from mines snapped at the gearbox end
Old Aug 11, 2010 | 07:44 AM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
karlos i have a s2 sitting in my ward if you need a cable/or speedo ... let me know
tommy
Old Aug 11, 2010 | 08:18 AM
12_Second_rst's Avatar
12_Second_rst
Dissconnect the dials and drive and see if the cables turning whilst your driving Mine did this and it was the speedo drive in the box
Old Aug 11, 2010 | 08:52 AM
Karlos G's Avatar
Karlos G
Balls Deep!
tommy
Cheers Tommy!
Yeah I was thinking that, good idea!
Old Aug 11, 2010 | 08:59 AM
RS500/364's Avatar
RS500/364
Speedo drive gear in the box !
Old Aug 11, 2010 | 11:04 AM
12_Second_rst
mine was bouncing becauase the diff bearings had collapsed and was making the speedo drive gears mesh sometimes then stop then it chewed the ring gear and the drive and the box smashed soon after within about 3 miles lol
Old Aug 11, 2010 | 11:10 AM
Karlos G's Avatar
Karlos G
Balls Deep!
hahahaha oh dear!!
This only happened since I removed the clocks the other day so I'm fairly certain it's a problem that end, but having had them out and made sure the cable was in properly i'm a bit confused.......
So I'll do the above and see whats going on!
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
sto6enc
Ford Mondeo Including ST
Sep 21, 2015 11:31 AM
Bransby
Sep 14, 2015 08:54 PM
Escortdriver1
Jul 31, 2015 02:36 PM
