Testing throttle switch
Old Jun 13, 2010 | 05:58 PM
PaulT's Avatar
PaulT
Default Testing throttle switch
Is there a way of testing the throttle switch if so how and what voltage should be at the metering head black box (you know what i mean) thingy
Cheers PaulT
Old Jun 13, 2010 | 07:57 PM
RSargie's Avatar
RSargie
as far as im aware its 8v at the black box, the throttle switch should click when you move the throttle. and to test it remove the plug and use a multimeter set to read ohm's between terminal 1+2 and it should read close to 0 when throttle closed and nothing when open. then put the meter on terminal 2+3 and it should read nothing when the throttle's closed and on half throttle. and close to 0 when on full throttle. then using the miltimeter set to volts you should have bottery voltage on terminals 1+3 of the plug and nothing on 2.
hope this helps.
Old Jun 15, 2010 | 11:59 AM
PaulT's Avatar
PaulT
hope this helps.
Cheers for that will have a look and do the tests, i only ask as when my car was rolling roaded the operator mentioned the full throttle enrichment did not seem to be working, he said either the fuel ecu or metering head black box.
Cheers PaulT
Old Jun 15, 2010 | 09:15 PM
RSargie's Avatar
RSargie
it could be the throttle switch if its the original one. the full throttle part ofthe switch is quite weak and the contacts often get muck on em so they dont make a circuit
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
rsguy
44
Sep 29, 2015 03:29 PM
cossie330
Sep 27, 2015 04:13 PM
