wont run right/help
wont run right/help
hi just fitted my turbo engine in my mk4 but its throwing out black smoke which i was told it was my furl metering unit , so took it apart and cleaned it all but its still coughing and banging . i then held up the flap on the metering unit and it ran fine so im unsure now so if anyone knows wat this is i will b appreciated
the flap controls the amount of fuel being added sounds like it's not set up right but if you not familiar with them then you've no chance, the black smoke is over fueling and when you say lift it up how much is it sitting down by on it's own
help
thanks guys very grateful 4 ur help , im not running it yet anyway . does anyone know wat sort of power i will get with a rebuilt engine with a piper cam stage3 ported an polished head by hot heads , t3 stage 2 hybrid turbo, scopion exhaust , unlimited boost ecu , k n , dump value . if any one knows it wud b great cus want 2 know a rough power ?
Eigdoog
13-09-2015 05:46 AM
