cam belt change
changing my cambelt today on the erst....just had a quick look under the car to see what its like before i start. do i have to lower the engine down to get the bottom pulley bolt off by gunning it with the air gun or is it possible to lock the engine and get it off with a spanner? cheers
if you can get the spanner on the pulley bolt by reaching under the car with it in gear and the handbrake on, or you could get it jacked up etc then get the spannner on the bolt and give it a whack with a hammer, there never mega tight
CrOwSoN15
14-09-2015 11:33 AM
Adam Graham
06-09-2015 06:04 AM
