oil preusre gauge
oil preusre gauge
woulded if any one else has got sandwich plate on the rst . got an autogauge oil preusre gauge . and was wouldering if people use a sandwich plate or t in to the oil turbo pipe at the back of the engine . and what presure they are getting hot and cooled .
all so has any one any pics .as i have mocil oil cool on mine to as well as sandwich plate .
you can get a t piece from ebay or burton's do it. you take out your oil pressure switch at the back of the block then put the t piece where the oil pressure switch was then put your oil pressure switch into the new t piece. you will be left with another female thread which you can connect your pipe that goes to your gauge.
Mark RS
12-10-2015 06:01 AM
