Silicone hose v brake fluid
S2 RST
I've just removed my ABS but still have the original reservoir. I found a bit of silicone hose in my toolbox the perfect length to block off the outlets, but what I need to know is whether the bit of hose will be up to the job as a temporary fix before getting a non-ABS reservoir? Is the brake fluid going to attack the hose and make it leak? Any help appreciated
Pic of what I mean, just in case, - you can see the U shape hose on the reservoir:
S2 RST
brake, compatibility, compatible, compatigble, fluid, handle, hose, hoses, res, silcone, silicon, silicone, teflon, tubing, vacuum
