how much bhp roughly can i get from my setup?
as above it still a project in the garage for now, iv bought some parts i havent fitted them all yet but was wondering how much bhp i should roughly get when i get it setup.
the car is a standard erst s2 mfi the part iv bought are a
piper 285 t2 cam
k&n air filter
magnex st steel exhaust
collins 31 actuator
collins chip with unlimited boost that what it said on ebay? thats all i know on the chip
any advice would be great im hoping to get 200bhp at some point, my mate has a 2.0 clio sport 210bhp and i would like to wipe the smile off his face lol. what other parts can i get that wont break the bank?
piper 285 t2 cam
k&n air filter
collins 31 actuator
Totally as karlos has said, mine was that spec, (nearly identical) with a front mount intercooler and a stage 2 turbo, car did 185brake at 17.5 psi did one run at 19psi but it was aborted because of det (was on tescos finest fuel lol) so probably could have hit 190-195 but i really wasn't chasing penis figures, the impressive figure was 205ft.lb of torque, the car did a 14.4 quarter mile with this set up which should be a fair bit quicker than your mates clio
PLUG ALERT , i have a cooler for sale in my for sale section,
Rob,
Rob,
YES I KNOW I CANT SPELL
but most fmic's are normaly a direct fit just need a bit of work nothink to hard realy
the thing is i dont know what im buying when it comes to the turbo how much wolud a stage 2 cost? my mate got a t4 for sale but he said i would be better off not buying it, he said it wouldnt run right?
it would probaly never come on boost on a 1.6 laglaglaglaglag lag lag lag lag limiter
I believe you can run porche bosch injectors but don't quote me on that. Also a 5th injector is a good idea as rob says. MF2 will do the trick.
Yes i totally agree but when on a budget then you have to get the best you can with the funds available. My friend has just sold his mf2 5th injector setup including crossover, driver,wiring loom and injector for 140 pound. EFI setup would cost you in the region of 500-600 for megasquirt with injectors,ecu, loom, inlet plenum, adapter plates ect
Balls Deep!
I will have done 600 by tomorrow evening
Had a day off driving today to do the fucking sump gasket..... AGAIN!!
Good opportunity to do an oil change and 'Touch wood' it's not leaking now....
Limiter is at 5000rpm and running 1bar now
I have all of your mods and a full frontal intercooler and mine made 165bhp @14psi.
my car has the following and made 204bhp @ the flywheel spiking at 15 psi
stage 2 turbo
chip
filter
exhaust
front mount cooler
piper cam
stage 2 turbo
chip
filter
exhaust
front mount cooler
piper cam
It made 169.3 bhp @ the wheels and he told me to add about 20% onto that for my flywheel figure which actually makes it 203.16 bhp @ the fly wheel or is that a bit generous?
don't get me wrong guys im not just making these figures up im just going off what a tuner has told me.
thats what mikeanics rollers said lol
Yeh im with you mate his rollers are Spot on ,He knows his stuff !!
Balls Deep!
and cheers for the recomendation boothy! needless to say it was a good drive home along the a34 on fri! aprt from when a woman didnt check her blindspot on a roundabout and I binned the car in to the kerb fooking my wheel up ;-(
[QUOTE=Rob_DOHC;4822833]but seriously (not saying your wrong mate) 200 brake at 15psi peak is bloody good going! [/QUOTE
No worrys mate, I was pretty pleased when I found out lol
I forgot something off my spec tho too, ive supposedly (was like this when I bought it) got an overbored bottom end taking it to aroud 1700cc. Weather this makes a difference or not I dont know.
and it does tend to hold 15psi in 4th and 5th due to there being more load I suppose
Yeah I saw his yellow escos and his WRC Spec one was on the ramp. He also had a tasty mk1 escort rally car there too.
Top bloke as you say.
was just a shame that he has to shut tho doors so his "neighbours" dont complain lol
How far did you travel mate ??
Cant wait to get mine on his rollers,its running efi,beige injectors, stage 3 turbo, front mount kent cam and a msd chip hoping for something around yours if im lucky
Balls Deep!
cheers for the vote of confidence Karlos and not just tarring me with the look at this idiot he doesnt know what hes talking about brush.
As if you did your wheel though, nightmare!
Your extra 100cc will make a difference yes, it increases the engines VE a little so all helps to make power.
Karlos: is was the wheel or my passenger wing and door lol
