need help!
Old Mar 2, 2010 | 03:02 PM
crighton13's Avatar
crighton13
Default need help!
i just put a new clutch in my rs turbo is a paddle clutch it is really light pedal and the bit is almost at the top of the pedal how do a adjust it
i no it is on a rachet but it isnt self adjustin?
any help? thanks
Old Mar 2, 2010 | 03:08 PM
sean_rsts2's Avatar
sean_rsts2
addicted to boost
did you change the clutch pedal and quadrant?
Old Mar 2, 2010 | 03:59 PM
crighton13's Avatar
crighton13
no mate what is the quadrant?
Old Mar 2, 2010 | 04:07 PM
sean_rsts2's Avatar
sean_rsts2
addicted to boost
am not 100% sure what the quadrant does mate but am pretty sure you have to upgrade the quadrant and clutch pedal to an adjustable one. i maybe wrong, but i upgraded mine when i fitted my ap organic clutch. it may just apply to ap clutches.
Old Mar 2, 2010 | 04:09 PM
James @ M Developments.'s Avatar
quite a few of the paddles do bit higher than the std cltuches, how high is the bite? Right at the top?
Old Mar 2, 2010 | 04:21 PM
crighton13's Avatar
crighton13
yea mate pritty much right at the top but the bite is tiny its either no bite or the clutch is out lol but it is right at the last bit on the pedal
Old Mar 2, 2010 | 04:31 PM
look at the pedal itself, above on the rear you will see a plastic ratchet and pawl unit, make sure all the teeth are in good order, as this can prevent the unit from self adjusting correctly
Rodreguez's Avatar
Rodreguez
need a quandrant gives more lift when you press the paddle as the radius is bigger!
Old Mar 2, 2010 | 04:32 PM
Rodreguez's Avatar
Rodreguez
i believe its a mk5 quadrant
Old Mar 2, 2010 | 04:34 PM
crighton13's Avatar
crighton13
ok if i have a look and they r all teeth are fine what car i do? lol
