Leccy window problem
Old Nov 3, 2009 | 09:56 PM
RS1HEN's Avatar
RS1HEN
Default Leccy window problem
on thursday, my passenger window, worked fine.
over the weekend till today, its got slower and slower,
and today, i can't actually see it going down, though when i look away its gone down a little LOL!
why would it do this?
any suggests?
Old Nov 3, 2009 | 09:57 PM
RS1HEN's Avatar
RS1HEN
forgot to add,
no sign of the engine, easing, or all of the other electrics dimming etc, when i'm trying to lower it
Old Nov 3, 2009 | 10:24 PM
RSargie's Avatar
RSargie
i had a similar problem and it was the earth wire at the connecting plug behind the speaker cover had gone green and brittle. its worth mentioning tho that at first glance it all looked ok and the othe wires wher fine. it wasnt untill i un pluged it and looked in the connector tha i saw it was knackered.
Old Nov 3, 2009 | 10:29 PM
Zetecfiesta's Avatar
Zetecfiesta
could be the motor thats died?
Old Nov 4, 2009 | 08:45 PM
RS1HEN's Avatar
RS1HEN
just seems strange that its gone from perfect to S~~# to in under a week?
ford..... as say they: fix or repair daily
Old Nov 4, 2009 | 10:06 PM
dangerousbrian's Avatar
dangerousbrian
first thing i would try is check the switch..then spray the motor and rubbers with plenty of wd40 or similar, and grease up the mechanism...mine was the same, seemed to die overnight..did this and they now work spot on. super fast in comparison..then it would be check earth..if none of them probably a new motor is required
Old Nov 4, 2009 | 10:19 PM
Dave_RS's Avatar
Dave_RS
Clean and tight up the switch inside contacts using a little flat screwdiver, and as above spray WD40 on the motor, rubbers and rails.
If the motor isn´t dying, it will be just like new after that.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
IainRS1700T
Sep 25, 2015 06:44 AM
pabloXR
Sep 21, 2015 12:42 PM
