engine mount help
Old Sep 23, 2009 | 10:53 PM
smitsturbo's Avatar
smitsturbo
Default engine mount help
as you might know i now have chorley street garages old pink rs turbo but its a "L" shell, & the rs turbo engine mount makes the engine sit too high & the bolt that goes thru the wheel well to engine is way off, do you need escort "L" engine mounts? cheers smits
Old Sep 24, 2009 | 07:00 PM
project rs's Avatar
project rs
as far as i know all the shells have the same holes in same places you sure you got right rs turbo mounts
Old Sep 24, 2009 | 07:09 PM
RSandy's Avatar
RSandy
my popular shell with rs turbo mount fitted perfectly fine, even built up 1 good mount out of several different cvh mounts, and it still fitted fine
u do have it in the right orientation and everything dont you?
Old Sep 24, 2009 | 07:42 PM
iansoutham's Avatar
iansoutham
OCD Victim
There is 2 different mounts on the MK3 Escort and 3 different mount brackets. If you use the wrong ones, the engine sits too high.
Engine mount
1980 - 1983
1983 onwards
Bracket
1980-1982
1982-1984
1984-1986
Old Sep 25, 2009 | 05:08 AM
JesseT's Avatar
JesseT
And also the mk3 and mk4 have the mounting holes in the inner wing at totally different height. The mk3 has the mounting level some 6-7cm lower.
Th early mk3 cvh and the late mk3 cvh engine mounting bushings have identical geometry although their external size is different.
Old Sep 25, 2009 | 11:38 AM
jodyhoare's Avatar
jodyhoare
+1
sounds like ur using a mk 3 mount on a mk 4 or vica versa
SmudgerByName
52
Jul 28, 2016 06:14 PM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
lockie
Jul 31, 2015 10:03 PM
