A question about boost!
Old Sep 12, 2009 | 06:37 PM
rsturbocabby's Avatar
rsturbocabby
Default A question about boost!
hey all...i discovered the problem with my rs and it was boost pipe
from the turbo...everytime i floor it and it get to around 14psi it will blow
off... is there anyway to manually turn the boost down?and what psi do
standard rs turbo's run at?
cheers all
joe
Old Sep 12, 2009 | 07:12 PM
jodyhoare's Avatar
jodyhoare
STD boost on a RS is 7 psi i belive mate, and you can manualy change it by adjusting the actuator mate
Old Sep 12, 2009 | 07:18 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
just get a new jubilee clip, should sort out the problem, or you may have an engine mount serieously worn and engine is rocking too much.
you can just wind the ctuator rod out a bit to drop the boost, but 14psi isn't high in terms of boost pressure.
Old Sep 12, 2009 | 07:27 PM
rsturbocabby
oh rite...so what bhp are the escort rs's from standard...and yeh a new clip sounds like the right idea...its a bit of a pain to get to though..ij just have to have play tommorow.!!
Old Sep 12, 2009 | 07:46 PM
jodyhoare's Avatar
jodyhoare
std bhp is around the 130 mark give or take mate,
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
